NPP operation
Old Sep 16, 2017 | 12:07 PM
oldbirdowner's Avatar
oldbirdowner
Default NPP operation
I installed a Mild2Wild kit. Did not work. I read that removing the fuse for the NPP would open valves all the time. I pulled the fuse and it made no difference. The valves still close. What's with this. Hard to not pull the correct fuse.
Old Sep 16, 2017 | 12:10 PM
RichKiss's Avatar
RichKiss
Does it work like it is supposed to normally. Could be bad vacuum lines if not.
Old Sep 16, 2017 | 12:39 PM
Richard F's Avatar
Richard F
Sounds like you have a vacuum line leak or they have been disconnected at the back.
Old Sep 16, 2017 | 01:31 PM
87SAM's Avatar
87SAM
If you had a vacuum leak, the valves would be open all the time. If the system is operating normally right now, I would triple check that you are on the correct fuse.
Old Sep 16, 2017 | 03:28 PM
oldbirdowner
Checked manual twice, watched multi youtube video's, plus great diagrams that came with the mild2wild, I am pulling the correct fuse. They are open when car is off, close when started , so vacuum lines have to be ok. . Have not had anyone check when hitting 3500 rpm. That's next. Not sure what the previous owner might have done to disable the option. Will check solenoid next to see if they bypassed it.
Old Sep 16, 2017 | 04:08 PM
Cuckoo's Avatar
Cuckoo
I would start over. Disconnect the M2W and put the original fuse back in the original slot. Then remove the fuse and see if it opens the valves.
it sounds like everything is working but maybe the M2W was connected wrong ?
Old Sep 16, 2017 | 04:28 PM
oldbirdowner
Nope, already tried that. Don't have M2W in at this time, I pull the fuse and still will not stay open. If I had some diagrams or schematics to work with, then might know what to look at, but right now I have nothing on this. Still researching the workings.
Old Sep 16, 2017 | 04:39 PM
LMB-Z's Avatar
LMB-Z
My guess is the switch at the rear is bad
Old Sep 16, 2017 | 04:43 PM
oldbirdowner
You talking about the one below the rear tail light?
Old Sep 16, 2017 | 07:31 PM
87SAM's Avatar
87SAM
Are they open when the engine is off?
Old Sep 17, 2017 | 06:35 AM
oldbirdowner
Yes
Old Sep 17, 2017 | 06:52 AM
jaybee924's Avatar
jaybee924
check your PM
Old Sep 17, 2017 | 07:09 AM
jaybee924's Avatar
jaybee924
Try this. An look at page #6 and #7.
http://www.nakidparts.com/sitebuilde...pplitels3a.pdf
Also are you trying to open and close them when the car is on or off?
Old Sep 17, 2017 | 08:09 AM
oldbirdowner
Ok, when car is ON. Also what is PM?
Old Sep 17, 2017 | 08:14 AM
HK770's Avatar
HK770
PM = PRIVATE MESSAGE
Top right hand of page at sign in area
Old Sep 17, 2017 | 09:58 AM
oldbirdowner
tks. I want to check to see if they open at 3500rpm first...
Old Sep 17, 2017 | 11:55 AM
jaybee924's Avatar
jaybee924
Click on your name then go to the private messages tab and click on it and then once the page change scroll down and you should see a title with my name under it click on it and open it up.
To NPP operation
Old Sep 17, 2017 | 12:08 PM
96GS#007's Avatar
96GS#007
Are you sure you have NPP? I ask this sincerely since we've seen more than one new owner go through this exact process and then when pressed for a pic, we see the mufflers are base mufflers.
If the flaps still "close" when pulling the fuse, this tells me you likely don't have NPP since there'd be know way for the solenoid to operate and enable the vacuum signal.
There are plenty of troubleshooting threads via search.
Post a pic of the muffler tips so we can see if you have the vacuum cans on the tips.
Old Sep 17, 2017 | 01:31 PM
oldbirdowner
It has the cans. Window sticker shows $1195.00 for Exhaust, Dual-Mode Performance. But here is a photo. Did not see them open above 3500rpm
Old Sep 17, 2017 | 01:32 PM
oldbirdowner
Well that is not exactly what I wanted.
