Radiator replacement
Old Sep 18, 2017 | 08:14 AM
Blake Brooks's Avatar
Blake Brooks
Default Radiator replacement
Im just looking for a recommendation. My radiator cracked and after trying to fix to no avail, I'm replacing it. Is there any reason I shouldn't be able to buy one of the cheaper ones or should I just put an AC Delco back into it? I know I run the risk of having the same problem down the road with either one so does it make much difference which one I get?
Old Sep 18, 2017 | 10:43 AM
BigMonkey73's Avatar
BigMonkey73
St. Jude Donor '15
I'd look at it as a perfect opportunity to install a Dewitts for a good cooling upgrade
Model # 1139105M works on a base and can work with stock fans
Old Sep 18, 2017 | 10:56 AM
Garry in AZ's Avatar
Garry in AZ
Rather than trying to save money on a cheaper one, why not by a better radiator and enjoy improved cooling and a higher quality product? Dewitts is a great choice, and there are others as well.
I don't understand the logic of replacing a factory part with "something cheaper". I look at it as, I have to spend the OEM money anyway, so why not spend a little more and get something even better. I like my replacement parts to improve the quality and reliability of the vehicle, not make it "just as good" or possibly even worse.
Old Sep 18, 2017 | 12:22 PM
Blake Brooks
Thanks fellas. I didn't do a ton of researching into it beyond the OEM vs cheaper product. I will definitely be going with the Dewitt's. Just need something quick to get my DD back on the road. Thanks again
Old Sep 18, 2017 | 12:28 PM
Turbo6TA's Avatar
Turbo6TA
2021 C6 of the Year Finalist - Modified
Blake ...
Just out of curiosity, how was the radiator damaged in the first place?
You said it was cracked, but how did that happen?
Old Sep 18, 2017 | 12:33 PM
Blake Brooks
Originally Posted by Turbo6TA
Blake ...
I was leaving a restaurant and hit a huge pothole. The lower supports don't seem to be damaged at all but I'm guessing that did it because it was spewing when I got home.
Old Sep 19, 2017 | 01:16 PM
C6ToGo's Avatar
C6ToGo
I think everyone would choose to replace it with the best....if not for one small factor....$$
Do you spend $50 or $650? decisions....decisions!
Old Sep 19, 2017 | 01:56 PM
ValegoC6's Avatar
ValegoC6
I agree 100& with Big Monkey 73.
Old Sep 19, 2017 | 02:35 PM
Turbo6TA's Avatar
Turbo6TA
Seems like everyone here has said that they would replace the radiator with a more expensive aftermarket radiator.
For me, I would replace it with a new OEM ACDelco radiator (cost is about $220).
For a basically stock C6, there is absolutly nothing wrong with the OEM radiator.
_________________________________
The OPs radiator did not fail because it was a piece of crap ... it failed because it was damaged by something that would have damaged [any] radiator that was installed in his car at the time.
Old Sep 19, 2017 | 06:17 PM
C6ToGo's Avatar
C6ToGo
Agree. When the OP posts the question:
"I'm replacing it. Is there any reason I shouldn't be able to buy one of the cheaper ones or should I just put an AC Delco back into it?"
and all the replies are to buy one at triple the price of an OE... just doesn't seem like he is getting the info he is asking for.
Amazon has an open box ACDelco (non-Z51) for $154 if you want to save money.
Old Sep 19, 2017 | 07:35 PM
68/70Vette's Avatar
68/70Vette
Is the factory OEM radiator all aluminum, or does it have plastic sides where the aluminum core is glued/epoxied in?
Old Sep 21, 2017 | 06:46 AM
icanski2's Avatar
icanski2
St. Jude Donor '13
I just installed one in my cammed, stalled, 160 deg thermostat LS3 that has a great tune. The Dewitts is definitely a well made part. However, my car doesn't really run any cooler with normal driving than it did with the stock radiator. It doesn't get as hot as it used to on the high end though. (if that makes sense? lol) Its not a miracle cure that will make your car run 160 degrees but it is an improvement. You really need upgraded fans and controller to get the maximum benefit from a Dewitts.
Old Sep 21, 2017 | 04:28 PM
Eritosthenes's Avatar
Eritosthenes
Absolutely right. I also have a 160 degree thermostat with new fan and module cooling an E-Force supercharged LS2 with a DeWitt's 1139105B double-thick radiator. It recently survived a five-miles-long traffic jam backed up behind a rural 4-way stop sign on a 94 degree afternoon after the total eclipse on August 21. My coolant temperature peaked at 227 with the A/C running full blast. Once I got past that traffic jam and got back up to 55mph, the coolant quickly dropped back to a rock steady 174.
Sooner or later the bottom six inches of almost all C6 radiators will become clogged with dead bugs, bits of leaves and twigs, sand, and dried mud. Water and compressed air cleaning from behind will help some, but the radiator will eventually need replacing. If you go the full DeWitts + fan + module route like I did, it will set you back about $1,200. I consider it a solid investment.
Old Sep 21, 2017 | 04:40 PM
Turbo6TA's Avatar
Turbo6TA
$1,200 for a radiator and a fan !
I think you have been hanging out a little too much at the Dandy Inn !
Old Sep 21, 2017 | 09:11 PM
Jmhornz71's Avatar
Jmhornz71
Check your upper and lower radiator supports real close. I hit a crater on 65 in Kentucky. I didnt notice any damage. Later I had a small drip from the trans line to the radiator took it to the dealer and I had cracked both the upper and lower radiator supports, fortunatley didnt damage the radiator just the trans line Insurance paid to fix it about 1300
To Radiator replacement
