0-60 timer?
Old Sep 20, 2017 | 06:34 PM
Chase0808's Avatar
Chase0808
Default 0-60 timer?
I have a 2009 A6 4lt and I've seen others use a 0-60 timer on the dash but I can't find one on mine. Does this start at a certain year or only on the Z06?
Old Sep 20, 2017 | 07:30 PM
SouthBaySurfer's Avatar
SouthBaySurfer
Never available on a C6; after-market perhaps.
Old Sep 20, 2017 | 09:18 PM
DWanderer's Avatar
DWanderer
6th Gear
Default Aftermarket Dashlogic
I got the aftermarket DashLogic unit. Connect it to your computer via USB to set up what you want to see and where. Then plug into your OBDII port. It has about 30 different monitor points. You can set up 8 pages. Each page has 2 lines on the heads up and one Driver Information Center. You use the driver side door lock down to cycle thru pages.
I have been real happy with it. It was a little off from the drag strip slips but pretty close.
Biggest problem is that I feel the need to go for my 60ft record at every light and stop sign.
http://www.dashlogic.com/products/pr...ol_corvette_c6
To 0-60 timer?
