Auto unlock not working
Old Sep 23, 2017 | 06:57 PM
knkali's Avatar
knkali
Default Auto unlock not working
just had the shifter assembly replaced on my 2006 A6 Vert b/c the shift lock solenoid was acting up and now the auto unlock feature isn't working. I tried resetting the DIC programs and resaved it to driver one as well as disconnecting the battery for a few seconds hoping it would reset thing.... Also replaced FOB battery but still no joy
Any help on what to try next would be appreciated.
TIA
Old Sep 23, 2017 | 07:04 PM
EVRose's Avatar
EVRose
Not sure what you mean. Can you explain exactly the symptoms?
Old Sep 23, 2017 | 08:24 PM
knkali's Avatar
knkali
the doors do not automatically unlock when i shift to park.
Old Sep 23, 2017 | 09:20 PM
HK770's Avatar
HK770
From the 11 manual: ...DIC , personal adjustments
Auto Unlock: This option allows
you to select whether the driver
door, both doors, or neither door
automatically unlocks when the shift
lever is moved into P (Park) for
automatic transmission vehicles or
when the ignition is turned off or is
in RAP for manual transmission
vehicles.
Press the OPTION button until
AUTO UNLOCK appears on the
display, then press the RESET
button to scroll through the following
modes:
. OFF
. DRIVER
. BOTH (default)
If you choose OFF, this option will
turn off.
Chevrolet Corvette Owner Manual - 2011 Black plate (62,1)
5-62 Instruments and Controls
If you choose DRIVER, on
automatic transmission vehicles, the
driver door will automatically unlock
when the shift lever is moved into
P (Park). On manual transmission
vehicles, the driver door will
automatically unlock when the
ignition is turned off or is in RAP.
If you choose BOTH, on automatic
transmission vehicles, both doors
will automatically unlock when the
shift lever is moved into P (Park).
On manual transmission vehicles,
both doors will automatically unlock
in RAP.
When the mode you want is
selected, press the OPTION button
to set your choice and advance to
the next personal option.
Old Sep 24, 2017 | 06:19 AM
knkali's Avatar
knkali
Yeah I read this in my manual also. Ty though.
Old Sep 24, 2017 | 09:51 AM
EVRose's Avatar
EVRose
All I can think of is there must be a switch on the shifter that wasn't connected when it was replaced. Other than that I got nothing.
Old Sep 24, 2017 | 10:14 AM
Sunnyvale Dave's Avatar
Sunnyvale Dave
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16,'19
I don't know how the doors get the signal that the shifter is in park and to unlock. Coincidences are possible, but this sure seems suspicious.
Mad*Max's Avatar
Mad*Max
TIA
was this to fix the problem of not being able to shift out of Park?
Old Sep 24, 2017 | 01:17 PM
HOXXOH's Avatar
HOXXOH
TIA
So if I understand it correctly, you had a problem with the shifter, someone else did a repair for you, and now the doors don't unlock when you shift into park like they did before the repair.
What I'd try next is going back to the someone else who obviously did something wrong. I assume you paid to have the repair done correctly and apparently it wasn't. If you attempt to fix their error using advice from other people, the original someone else can and most likely will claim you damaged something and you'll end up paying to get their screw-up fixed.
Hopefully you paid with a credit card, since that gives you a little clout if the someone else doesn't fix or refuses to fix the problem.
I'm not thinking this is a major problem for the someone else to fix, but if you had to have the someone else do the initial repair, I'm guessing you don't have the ability to fix the current problem.
Old Sep 24, 2017 | 02:50 PM
knkali's Avatar
knkali
yes
Old Sep 24, 2017 | 02:52 PM
knkali's Avatar
knkali
ty for your input.
Old Sep 24, 2017 | 04:07 PM
Mad*Max's Avatar
Mad*Max
yes
I would take HOXXOH's advice, however, and I know this doesn't help you now but it seems like overkill to have the whole thing replaced. Even if you didn't want to tie the pawl there is another part that could be replaced.
Old Nov 16, 2020 | 08:55 PM
Garrett Long's Avatar
Garrett Long
4th Gear
I know this thread is old but curious if you ever found a fix. My 2013 is doing same thing although I never had any shifter work done. It unlocks fine if I press the unlock button.
Old Nov 16, 2020 | 09:28 PM
Vette_DD's Avatar
Vette_DD
New forum member who asked for help hasn't ever come back. Must be a troll. I've removed my helping comments.
To Auto unlock not working
