Coolant service
Coolant service
I have an '11 GS. I just made an appointment with my local Chevrolet dealer to have the antifreeze flush on the car. The car only has 9000 miles. But the car is also six years old. They quoted me 159 for the service. Does that sound reasonable. Also they quoted me 199 for a brake flush service. Any opinions-comments
Price is probably competitive. 2 gallons of coolant is about $30, then add distilled water, shop consumables and min $100+ for labor. Brake fluid seems comparable too. I just did the coolant myself and it took me longer than it would have in a shop but I don't really have anything else to do. Brakes are another issue due to ABS flushing and no Tech-II. My biggest concern on the brakes with whoever does the job is spilling of fluid onto the car. When I had a C4 I had a local shop with a good reputation do a complete brake job including fluid. I did not notice at the time but a few months later noticed all the paint below the brake booster was gone. They had spilled fluid and not cleaned it up. No more business for that shop. Now that I have a C6 I will be much more selective and question the tech on his procedures. Good luck!
Received 4,713 Likes
In the ballpark
Thanks. I have a local guy who maintains the family cars. He changes the oil on the Vette in the spring. I figured most of my Corvette buddies use this particular dealership for their services.
Received 3,088 Likes
2021 C6 of the Year Finalist - Modified
Vins ....
You know, changing the coolant in these cars is really a simple process doing it yourself.
I just did mine (2011 GS with 17,000 miles)
Received 2,061 Likes
If you trust the local guy to work on your wife's/kid's cars, you should trust him to change fluids on your Vette. Then tell your Vette buddies how well you were treated and how much you saved.
Replace the thermostat too?
Received 2,481 Likes
St. Jude Donor '15
"In honor of jpee"
I just thought of one more thing. Make sure you have (or your shop has) jacking pucks and knows where to jack up your Vette. Don't assume that they know what they are doing or you'll end up with cracked floor pans or worse.
OP, both are reasonable compared to what can happen if neglected. The dealer will use the correct coolant, designed to run in our aluminum systems and minimize electrolysis. As for the brakes, it's an easy job for the diy inclined, but as mentioned, make sure you thoroughly wash the calipers and wheels, and closely inspect around the master cylinder area in the engine compartment. I can guarantee any shop won't pay the same attention to detail you will. If any doubt about under the hood spills or splashes, you could carefully rinse the area with water that will neutralize any spills or splashes.
Thanks for all the opinions and recommendations. I've used this particular dealerships service department for the headlight recall a while back. I'll let them to The A/F service. It's good to have some dealership records on service when you go to sell.
If you change the coolant yourself, just buy to correct kind. You need "Dex-Cool".
And since the system holds 12 Qt total of fluid, you will need 1 1/2 gallons of Dex-Cool in order to give the car a 50% Dex-Cool to 50% water mix.
Here is the brand of Dex-Cool I used:
I spent a little more time by flushing the system more than once ...
After I initially drained the system, I then filled it back up with water and ran the engine until the water got hot ... Then drain again.
Do this a couple more times until the fluid comes out very clear (no Dex-Cool is left in the system at all).
Then pour in your 1 1/2 gal of Dex-Cool and add water until full.
Start engine a run till hot. The stystem will 'burp' out air and you need to add more water ... keep adding water until the coolant level stabilizes at the full mark on the plastic surge tank.
Your are now done, and have a very clean 50-50 mixture of Dex-Cool and water.
1 Gal. Prestone Dex-Cool at Walmart ($14.47)
For a 50% Dex-Cool to 50% water mix, you will need a total of 1 1/2 gallons of Dex-Cool
Link: https://www.walmart.com/ip/Prestone-...-1gal/16889200
Yup ... A plastic petcock on the passenger side of the radiator.
I just raised the Rt / Front of the car (using a hockey puck pad) at the Rt / Front jacking point. All I needed to raise it was about 9" so I could lay down and have access to petcock.
The black plastic petcock is mounted sideways (horizontal) ... not vertical.
It's accessed from in front of the right / front tire. You reach your arm in there, and really don't even have to get your body under the car at all.
