**Need Feedback Please**
Old Oct 9, 2017 | 12:43 PM
Jason W Dreher's Avatar
Jason W Dreher
Default **Need Feedback Please**
I have this annoying squeal and squeek sound when the motor is cold. The sound goes away after warming up.. I've changed the tensioner, tensioner pulley, idler pulley, alternator (I was going to change anyhow), and belts.. I put a gatorback belt on... The sound went away for about 2 weeks but now it's back even louder.. The harmonic balancer does not have a crazy wobble.. The balancer have a very slight wobble after staring at it for awhile but a slight wobble. Thoughts, feedback, experiences?
Old Oct 9, 2017 | 01:12 PM
Vette_DD's Avatar
Vette_DD
You might want to post a little more about your car. Model Year, model, non-OEM options added, mileage.
Old Oct 9, 2017 | 01:32 PM
Jason W Dreher
2005, 46000 miles, base..
Old Oct 9, 2017 | 02:48 PM
Not So Fast's Avatar
Not So Fast
Mine was slight for over 2.5 years, no noise but worsened lately so I had it replaced for peace of mind. 2011 GS 30K miles
Old Oct 9, 2017 | 04:33 PM
Jason W Dreher
It seriously barely moves if it even does.... I may be dillusional from staring at it to long.. I'm trying to figure out what this sound is on start up..
Old Oct 10, 2017 | 08:44 AM
irok's Avatar
irok
sounds like the elastomer rubber between inner and outer hub of hb has delaminated.look at it with engine not running.the front face of inner,outer and elastomer should be near level with a straight edge when you check it.look at the outer hub to make sure it has not moved forward or backward on the inner hub.some times you may not be able to see any obvious issue but can hear it when running.do not use a GM replacement hb or you may have to redo in a short period of time.if the elastomer is protruding from the hubs or sucked into the hubs there's your problem
Old Oct 14, 2017 | 12:29 AM
Jason W Dreher
Interesting.. Thanks..
I actually removed the serpentine belt to test and the sound is still there. It would have to be the ac belt then, right? I just changed it about 4 months ago. It wasn't making sounds then, I just changed it for maintenance purposes. Thoughts?
Old Oct 14, 2017 | 06:29 AM
irok's Avatar
irok
did you also change the AC tensioner?
Old Oct 14, 2017 | 12:23 PM
HOXXOH's Avatar
HOXXOH
That's the pulley making noise on mine when cold. If it ever gets out of the 90's here, I have several things on my maintenance list to do.
Old Oct 16, 2017 | 08:24 AM
Jason W Dreher
The ac tensioner pulley?
To **Need Feedback Please**
