gm full width spoiler
Old Oct 10, 2017 | 09:50 AM
lodawg's Avatar
lodawg
Cruising
Default gm full width spoiler
there is a slight gap on both of it after installation is that normal
Old Oct 10, 2017 | 09:55 AM
ruxvette's Avatar
ruxvette
2016 C6 of Year Finalist
Well, gee, I'm flummoxed. Did you forget the word "ends"? Did you do the install? Did you use tape or bolt it down? Were the installation instructions followed? Any pictures?
Old Oct 10, 2017 | 10:06 AM
lodawg's Avatar
lodawg
Cruising
bolted down ends look good but closest to third brake light slight gap
Old Oct 10, 2017 | 11:45 AM
ncvette_1FUNRIDE's Avatar
ncvette_1FUNRIDE
2015 C6 of the Year Finalist
A photo is worth a thousand words.
Is your spoiler OEM or aftermarket?
OEM should fit just fine. Maybe you didn't drill the holes big enough for a little play and the spoiler was put in a bind as you tightened it up or it is not sitting flush against the body because of this.
Old Oct 10, 2017 | 12:03 PM
lodawg's Avatar
lodawg
Cruising
its OEM just gap as water slides through.can see a little daylight if looking from behind .
Old Oct 10, 2017 | 12:35 PM
Turbo6TA's Avatar
Turbo6TA
2021 C6 of the Year Finalist - Modified
Show us a good close-up photo of the gap
Old Oct 10, 2017 | 12:45 PM
WideVette's Avatar
WideVette
Old Oct 10, 2017 | 01:41 PM
ncvette_1FUNRIDE
Loosen up all of the bolts slightly. If there isn't any play in the holes so that the spoiler can move slightly with the bolts slightly loose then the holes are not big enough.
If there is no allowance for a slight movement as you tighten the bolts part of the spoiler can get in a bind and not lay flat.
If it will lay flat (or very close) when there are no nuts on the bolts, then it is not the spoiler but the installation. If it won't lay flat, you may have to enlarge the holes slightly.
Also, it must be centered and you should probably "hand snug" all of the bolts and then tighten them from the center out to each end..
To gm full width spoiler
