Z06 Wheels
Old Oct 11, 2017 | 11:11 PM
Tom Roy's Avatar
Tom Roy
Default Z06 Wheels
Hello everyone. I came across a nice set of Cray Manta wheels 19/20. They came off a 2014 Z51. Front are sitting on 265/30/19 and the rear is on 305/25/20. The lug pattern for the wheels are 5x120.65. I have a 2008 Z06, I was wandering if anyone knew if theses would be ok to put on the Z06, has anyone done this? Thanks
Old Oct 12, 2017 | 12:24 AM
Grimlock13's Avatar
Grimlock13
While they might "work" *, they would look goofy as the tires wouldn't be as wide.
*You could use very large wheel spacers to make them fit.
Last edited by Grimlock13; Oct 12, 2017 at 06:43 AM. Reason: forgot about front brake clearance
Old Oct 12, 2017 | 02:04 AM
LMB-Z's Avatar
LMB-Z
Not wide enough for a Z06. Stock fronts are 275 and rears are 325. I think IF they would fit, it would look very odd. I'm not sure the offset is correct either. Your Z06 has bigger brakes than a 2014.
Old Oct 13, 2017 | 09:59 AM
Tom Roy's Avatar
Tom Roy
Thanks Guys, I appreciate it.
To Z06 Wheels
