Engine sound
Old Oct 30, 2017 | 08:10 PM
txpower501's Avatar
txpower501
Cruising
Default Engine sound
Hello All. New here, just purchased an 08 3LT Automatic Coupe w/ 26000 miles from one of the users on here. Ive put 1200 miles on the car since I bought it. When I bought the car I had it inspected at Chevrolet in the same city where I bought it. I've since had it to my dealer once for a TSB, and then just had it back for the state inspection. I have an engine noise that I think just started or I'm just starting to hear it... It almost sounds like direct injection but half as loud. Obviously, the car doesn't have direct injection. Kind of worries me a bit... Not sure what it could be. Any ideas? Sounds like it could be an exhaust leak... But I dunno. I'm no mechanic. Any ideas?
Old Oct 30, 2017 | 08:15 PM
User Omega's Avatar
User Omega
It could just be the injectors making normal sounds. Can you capture this sound on video?
Old Oct 30, 2017 | 08:25 PM
txpower501's Avatar
txpower501
Cruising
Originally Posted by txpower501
I'm doubting it would turn out, but I'll check.
You can't hear it in the video. Probably just need to listen to another to calm my concern.
Old Oct 30, 2017 | 11:18 PM
buckmeister2's Avatar
buckmeister2
I am confused...you said you bought it from one of the "users on here", then you say you bought it from a Chevy dealer. I realize it could be both, I am just curious.
I would advise you to never get an "inspection" from the seller, even if they are a dealer. And, unless you have an extended warranty that requires you to use a dealer, I would find a reputable independent to do any of the work needed.
Old Oct 31, 2017 | 02:04 AM
txpower501's Avatar
txpower501
Cruising
I did buy from an individual. I had it inspected in the city where I bought it from the local dealer. I bought it 500 miles away from home. I can see how my message could have been confusing.
Old Oct 31, 2017 | 06:00 AM
enventr's Avatar
enventr
Bring the car to a corvette mechanic or the dealer would be your best bet if you do not have any experience working on cars.
Old Oct 31, 2017 | 06:05 AM
CMY SIX's Avatar
CMY SIX
it is an ALL aluminum engine you WILL hear things that you didn't in a cast iron block
To Engine sound
