Automatic Trans Temp Missing
Nov 4, 2017 | 05:48 PM
Cruising
Hello!
I have a C6 2005 (
1G1YY24U055102860 ) and GAGES Button don't show the Transmission Fluid Temperature. I can see everything else just fine.
Any comments to help?
Nov 5, 2017 | 04:55 AM
Does it display "Trans temp" and then nothing or altogether it is just missing?
Nov 5, 2017 | 05:00 AM
Cruising
Quote:
Originally Posted by
User Omega
Hello User Omega,
Is just missing. No "Trans Temp". I just realize that was missing the info when I was reading the owners manual.
Nov 5, 2017 | 05:34 AM
I hope another user will be able to give you something. I didn't expect you to come back with that.
Nov 5, 2017 | 06:50 AM
Cruising
User Omega
Thanks for the help anyway!
Nov 5, 2017 | 07:20 AM
St. Jude Donor '11
Oldtimer
When you go through the different reading does the DIC show Trans Temp and no reading of the temp. or does it not even show that?
Nov 5, 2017 | 07:51 AM
I've never heard of this happening before.
Nov 5, 2017 | 11:50 AM
Sounds weird one-off electronic glitch
Try rebooting computers.
Disconnect battery a few minutes & reconnect, refreshes everything.
Check again.
Might get lucky as so many of us have curing electronic flukes.
Nov 5, 2017 | 11:54 AM
Landru
Check again.
Or the sensor went bad in the transmission.
My 07 has had the oil pressure sensor and light sensor on dash go bad.
Nov 5, 2017 | 12:06 PM
wayback
Or the sensor went bad in the transmission. My 07 has had the oil pressure sensor and light sensor on dash go bad.
Could be.
OP's missing xmission temp reading, same as your symptom?
Does this sensor have a dual role of temp & pressure?
A reboot might be a cheap place to start for showing what it isn't.
Nov 5, 2017 | 12:15 PM
Landru
Could be.
There are seperate sensors for temp and pressure.
My oil pressure sensor went bad and read 80 psi all the time, even in acc mode without the eng running.
Have not had to replace the transmission temp sensor or ever heard of one going bad......
Nov 5, 2017 | 12:23 PM
wayback
There are seperate sensors for temp and pressure...Have not had to replace the transmission temp sensor or ever heard of one going bad ...
Neither had I.
Yet something's sending temp data to ECM for display, no?
Just has the feel of C6's infamous electronic ghosts, a simple reboot often rectifies this stuff.
Nov 5, 2017 | 12:27 PM
I think if a sensor was bad he would either get an off the chart reading for the temp or it would stay at zero or maybe fluctuate up and down erratically. I can't believe it would make "Trans Temp" disappear off the list.
Nov 5, 2017 | 01:11 PM
Cruising
BWF07
Hello BWF08!
Nothing. Doesn't show that.
Nov 5, 2017 | 01:13 PM
Cruising
Landru
Neither had I.
I went to a GM dealer and the scanner shows no error.
Nov 5, 2017 | 01:15 PM
Cruising
EVRose
I will check that. Where the sensor is locate?
Nov 5, 2017 | 05:38 PM
location
Flavio Rosario
internal to the trans.the trans temp sensor is part of the trans fluid pressure manual valve position switch.drop trans pan and you can access without removing valve body.if issue with it it should set DTC P0713
Nov 6, 2017 | 09:16 AM
Flavio Rosario
Nor would it, not for this.
Try a reboot, start w/ a clean slate & proceed from there.
Please report back.
Nov 10, 2017 | 09:34 AM
Is it an automatic? Assume it is....don't think manuals display trans temp on the DIC.
EDIT: I see where you state Auto in your title. No clue now.
Nov 10, 2017 | 11:54 AM
Check the RPO codes. Maybe it wasn't always auto. Or even more likely, maybe the computer failed and was replaced with the manual trans version.
