radiator support broken nut insert
Old Nov 6, 2017 | 02:08 PM
g23crawler's Avatar
g23crawler
Default radiator support broken nut insert
As im getting farther into my twin turbo build I noticed my radiator support was broken on one side. As I was taking it off I noticed that the front nut insert broke loose and the bolt and nut insert just spin on the inside of the frame. Has anyone had this happen? I was able to put enough pressure on the nut insert to get the bolt off, but I obviously wont be able to tighten it down. I did not see any access holes in the frame to replace it or weld the nut back to the frame.. Anyone have any ideas?? My build is kind at a stand still till I can get the radiator support back on.
Old Nov 6, 2017 | 03:32 PM
jaredtxrx's Avatar
jaredtxrx
If the radiator support is cracked a little you can usually get this re-welded by anyone that can weld aluminum.
The riv-nut replacement: I have heard some folks that just drilled the hole all the way through and used a traditional bolt/nut combination if the riv-nut was broken.
Old Nov 6, 2017 | 03:53 PM
g23crawler's Avatar
g23crawler
I could fix the support myself but it is all bent up and I would rather just buy a new one. I was more concerned about the nut insert. I couldn't find any access holes to get a hold of a nut on the inside of the frame. Therefor a standard nut and bolt would not work.
Old Nov 6, 2017 | 08:03 PM
CMY SIX's Avatar
CMY SIX
you'll have to look around but the DO make a "riv-nut" fix for that
Old Nov 7, 2017 | 03:06 PM
lovinmyls1's Avatar
lovinmyls1
New radiator supports don't come with riv nuts attached. You will have to buy the nuts separate and install with riv nut tool.
Old Nov 7, 2017 | 07:06 PM
CMY SIX's Avatar
CMY SIX
Talk to a "body shop" mine was repaired at one and the had a "weld in" unit
Old Nov 8, 2017 | 02:57 PM
salt6's Avatar
salt6
This one does.
https://www.corvetteforum.com/forums...id-plates.html
Old Nov 8, 2017 | 03:12 PM
g23crawler's Avatar
g23crawler
I forgot about actual riv nuts, i am just going to drill out the old one and replace it with a riv nut.
Old May 23, 2021 | 08:46 PM
trapshooter12's Avatar
trapshooter12
3rd Gear
Who is DO?
To radiator support broken nut insert
