Rear leaf spring bushing replacement difficulty
Old Nov 16, 2017 | 01:50 AM
lendellmm3's Avatar
lendellmm3
Default Rear leaf spring bushing replacement difficulty
I ordered some new stock like bushing from corvette central, looks pretty much stock and not a lowering bushing. However trying to thread in the new bushing gets stuck about half way and can’t get a 10 mm at the top of the bolt to get to to thread the rest of the way.
The old bushing screws in easily by hand through the whole bolt. Any suggestions?
Ended up taking out the whole rear leaf spring so I could look and make sure I didn’t strip the female threads on the leaf spring. Thought I might of taking out the broken bolt when the bushing ripped off while driving evidently
This 45 min switch ended up taking half my day like a SOB...lol
Old Nov 16, 2017 | 06:50 AM
wayback's Avatar
wayback
I would take them both to Home Depot or Lowe's and find the nut that fits your stock bolt. Now try that nut on the new ones. If it does not fit you will need to return them and try another brand.
If they do work you might be able to use pliers on a rag wrapped around the bushing to thread it through the spring.
Old Nov 16, 2017 | 09:36 PM
torquetube's Avatar
torquetube
I don't think there's anything wrong with the inserts in your springs. My Corvette Central repro bolts were pretty stiff as well. The black paint they've got on them is pretty thick.
I'd suggest just applying some lubricant and persevering, or as a last resort chasing the threads with a loose die.
Old Nov 16, 2017 | 10:37 PM
HOXXOH's Avatar
HOXXOH
I had the same problem recently. Chasing the threads with a nut or even a standard die is not enough to get the heavy paint off. Been there and failed. Either wire brush or use a solvent to remove the paint. It may take some lube to help the install.
Old Nov 17, 2017 | 01:49 AM
lendellmm3's Avatar
lendellmm3
Ended up taking the new bushing to a machine shop we tried cleaning the threads w a wire brush and got all the paint off but still would get stuck. He had to rethread it partially on his lathe somewhat loose instead but it fits now. Just crappy quality from corvette central.
And from all the threads you can’t install these without taking the lower control arm off. I tried jacking up the rear leaf spring and there’s still about 1.5 “ that you can’t shove underneath. Not sure if the lowering bolts I’ve seen have a shorter bolt length that makes it easier to slide under neath
This ended up being a 9 hr adventure, removing the broken bolt first then trying to get these bushing without taking apart the suspension, then fixing these bushing
Old Nov 17, 2017 | 08:31 AM
HOXXOH's Avatar
HOXXOH
I had no problem having enough space to R&R the leveling bolts without touching the lower control arm. Drop the tie rod, unbolt the swaybar link, pull the upper control arm bolts, and the two shock mount bolts. Because I have the F55 suspension, I also needed to unplug the shock and remove the sensor linkage.
I most certainly agree that whatever process that Corvette Central's supplier is doing to the threads, needs to be addressed. I spent more time fixing the thread issue than the entire rest of the job.
To Rear leaf spring bushing replacement difficulty
