Question about changing spark plugs.
Old 11-19-2017, 12:00 PM
  #41
LMB-Z
LMB-Z's Avatar
Change your blinker fluid while you're at it. The air in your tires is also old...I would let the dealer change it too. I'm sure they will only charge $100 to change the air.
Old 11-20-2017, 08:29 AM
  #42
BadAV
BadAV's Avatar
Received 2,674 Likes on 1,699 Posts
No reason to change the plugs at your low mileage, even on a Mercedes. You will notice one of several symptoms if your plugs are going bad. Most common is a drop in gas mileage. Hard starting is another. Rough idle is another. Uneven acceleration is another. Pull a couple of plugs and see what they look like if it makes you feel better.
Old 11-20-2017, 10:41 AM
  #43
windyC6
windyC6's Avatar
Originally Posted by Mad*Max
But you will need to change the wires while you are at it - I have had many professionals say not to put the old wires back once you have pulled them.
Me thinks we at this forum get a little carried away with the term "professionals" these days. Sometimes maybe the wires will need to be changed, and sometimes (most of the time) they won't. But to say that they should be changed every time one changes their plugs is just.....well..... Too many "professionals" these days want to pat themselves on the back by trying to impress the un-informed with knowledge that just may not be true. ......
Old 11-20-2017, 10:54 AM
  #44
jaredtxrx
jaredtxrx's Avatar
Originally Posted by important
I should have clarified, this is for a 2010 Mercedes GL550 not my C6.
But I would imagine that its still overkill to change them at 21kmi even though these engines are POS.
Will pull one as suggested, just worried about re-seating it properly.
Page 37: https://www.mbusa.com/vcm/MB/Digital...ce-Booklet.pdf
60,000 mile (or 6 years) change interval for GL550. I would not do spark plugs based on time and change at 60k.
Quick Reply: Question about changing spark plugs.
