15” conversion
Old Nov 18, 2017 | 11:46 PM
Huntervincent_6's Avatar
Huntervincent_6
Default 15” conversion
I have a 07 base model c6 and I’m going to do the 15” conversion but I’m going to keep my stock base fenders, what’s the widest “ wheel” I can run if I do a 15?? Would a 15x10 be ok? Or will that he to wide for the stock fender
Old Nov 19, 2017 | 12:22 AM
cb1980's Avatar
cb1980
depends on the offset and backspacing, the stock wheels are either 19x10 or 10.5, can't remember off the top of my head
Old Nov 19, 2017 | 12:13 PM
Huntervincent_6
what would be the ideal back spacing width size ect.
Old Nov 19, 2017 | 11:33 PM
cb1980's Avatar
cb1980
I haven't ran the 15" wheel on my C6 because I have no interest in doing the conversion to make them fit, so I don't know all of the specifics but depending on tire width used, you should be able to get away with a 15x10 with around 6 to 7 inches of backspacing and that should put you close to flush or possibly sticking out a little bit.
there is a guy who runs at one of our local tracks with dark stars in 15x10 but I think his backspacing is closer to 8 inches and his stick out about an inch or two past the edge of the fender
Old Nov 20, 2017 | 06:30 AM
Huntervincent_6
Awesome thanks for getting me in the right direction
Old Nov 20, 2017 | 11:57 PM
cb1980's Avatar
cb1980
no problem, good luck with the search and finding a set of wheels that work for you
Old Nov 21, 2017 | 02:46 PM
subfloor@centurytrans's Avatar
Supporting Vendor
2024 C6 of the Year Finalist - Modified
2020 Corvette of the Year Finalist (track prepared)
2019 C6 of Year Winner (track prepared)
Unless you're gonna be making some crazy power and/or plan on launching it at 5000RPM (or more) why not save yourself the hassle and just go with a setup similar to mine?
315/35/17" Hoosier drag radials on C4 ZR1 reproduction rims - regularly cut mid 1.3 60ft times launching it at around 1800RPM.
I almost did the same thing a couple years back only to realize that I was getting as good (and in some cases better) 60ft times than full blown race cars will slicks running in the 9s.
Old Nov 30, 2017 | 06:36 PM
Huntervincent_6
no rubbing with a 315? And what kind of power are you making?
Old Nov 30, 2017 | 06:41 PM
Huntervincent_6
I’m also an 800hp base c6 btw lol I didn’t know what you consider crazy power
Old Nov 30, 2017 | 07:11 PM
Supporting Vendor
It would rub if I tried driving with them on the street but at the track they're totally fine.
Not a clue as I've never had it on a dyno. Best ET so far was 10.069 on July 4th and I'm expecting it'll run high 9s in the winter.
To 15” conversion
