New owner - increasing front ride height
Received 8,880 Likes
Hello,
I just picked up a 2012 Grand Sport this past weekend, and it appears the previous owner lowered both the front & rear of the vehicle. The front is too low (front lip sits 3.25" above the ground) and scrapes on everything. I can't even get in and out of my driveway without scraping the front stock lip. I'm wanting to add a ZR-1 front splitter & side skirts, but am afraid that will get ripped off immediately. What is the easiest way to raise the front end up a bit, and what is the stock ride height? Thanks very much for the assistance.
Hello,
In any event - per the user manual the plastic air dam is designed to scrape on driveways and speedbumps without being damaged. Mine does it too, I'm at 3".
Dont worry about it, its a 'feature'. My car is about 3/4" lower than stock which is about same as yours.
Not sure if this poster means the bottom of the air dam (black plastic) or bottom of the bumper (fiberglass, body color) as 6" seems very high for the air dam.
Do the opposite of what this guy is doing...notice he uses a floor jack to relieve the tension on the spring before turning the adjustment bolts. I recommend pre-lubeing the bolts and letting sit a bit for the lube to have time to work.
JABCAT (11-22-2017)
Hello,
It is 3-3/4" from the ground up. If I were in your situation I wouldn't mess with an expensive splitter unless you are willing to be ok with it getting scraped up and possibly damaging underneath the bumper where it attaches too.
My stock splitter or lip got pushed back in the center by a parking curb and cracked underneath the painted bumper around 1 mounting hole underneath the bumper. Can't see it. I was able to secure it by holding the jam nut against the now larger hole while tightening and using a small strip of 3m trim tape. Looks and works fine.
Any way its part of owning a Grand Sport I guess.
Received 2,062 Likes
Stock height for a base measured from the floor to the fenderwell lip at the centerline of the wheel is 27.4 for front and 28.7 for rear.
Z06 is 27.3 front and 28.2 rear. All dimensions are taken with no driver and a full gas tank. The acceptable tolerance is +/- .4".
I would set a GS to the Z06 specs.
Drive it a bit, maybe 50 miles or so to let everything settle in place and recheck. Once you're satisfied, get an alignment.
Do the opposite of what this guy is doing...notice he uses a floor jack to relieve the tension on the spring before turning the adjustment bolts. I recommend pre-lubeing the bolts and letting sit a bit for the lube to have time to work.https://www.youtube.com/watch?v=kenKE_SYSK0
Hello, yes that is correct and the method I used to raise my 2011 GS when I picked it up.
After you raise it back to the OEM height in line with the measurements posted using the center of wheel ground to wheel well lips .
I then had a PDFAT street performance specs alignment done. This should give you less camber and better inner tire wear in front.
JB
Exactly...lift the car and support it with stands at the height needed to gain access. Then use a small jack with a small piece of wood (for better access to the spring) to raise just the end of the spring to reduce tension on the ride height adjustment bolt. As you put pressure on the spring with the jack it will almost lift that corner (and may) but the spring will come up at the last moment
Thanks to everyone for the help. I was able to raise the front up about 1.5” today so now the front fender well measures 26.5” from the ground & no more scraping getting out of my driveway.
jdvann (11-25-2017)
Hello,
Just a FYI, but the ride height bolts are use to 4 corner balance the car.
If the old owner just slammed the car down with the bolt lowered all the way down, he in fact de-4 corner balanced the car isntead.
Use the Z-06 heights to get you close, then when you have time, find a shop that get the car on scales to final tune the corner balance in the end.
At 7:38, you can see the tech in the pit doing a one over under the car, as well as final adjusting ride height bolts to the corner balance it as well.
