2010 with A6
Old Nov 23, 2017 | 06:59 PM
WKM's Avatar
WKM
Default 2010 with A6
This might have been asked before, but I see no info on it. What does it do for you if you go to competive mode in the A6? I see the benefits in the owners manual for the manual transmission but nothing really mentioned about the auto.
Old Nov 23, 2017 | 09:18 PM
hrt vlv's Avatar
hrt vlv
You still have AH, so you have a saving grace. Recommended for autox and track
Old Nov 23, 2017 | 09:34 PM
Turbo6TA's Avatar
Turbo6TA
2021 C6 of the Year Finalist - Modified
This may help you understand this a little better .....
Attachment 48342151
Old Nov 23, 2017 | 09:40 PM
Turbo6TA's Avatar
Turbo6TA
And as far as placing your A6 trans in the 'Sport' mode vs the leaving your A6 in 'Drive' ....
In Sport mode at wide open throttle (WOT), the transmission will alow the engine RPM to go slightly higher before shifting to the next higher gear. The shifts will also be just slightly firmer ... Again, this is only during WOT.
Just 'slightly' is the key word here ....
Old Nov 23, 2017 | 09:50 PM
WKM's Avatar
WKM
Does the competitive driving mode even work if you are in sport mode?
Old Nov 23, 2017 | 10:19 PM
Turbo6TA's Avatar
Turbo6TA
Yup ......
Old Nov 23, 2017 | 10:33 PM
Oh Boy's Avatar
Oh Boy
In 2011 they added the Dual Mode Steering Rack which when you took the active handling off or put it in competition mode the steering became much more stiffer to provide much better driver communication with the tire patch.
WKM's Avatar
WKM
Thanks turbo I’ll have to try it some
Old Nov 23, 2017 | 10:35 PM
WKM's Avatar
WKM
Mine is 2010 model so it want have that then
To 2010 with A6
