Shock Replacement Question
Old Nov 29, 2017 | 11:35 PM
  #41
LowRyter's Avatar
LowRyter
Originally Posted by C6 Snowboarder
sounds like shocks should be replaced after one of 2 conditions: 1, every oil change or 2, if one ever hits a small or large pot hole. Change them out to be sure. Most cars can handle a pot hole but Corvettes are much more high maintenance. Like, dont drive them in the rain, store them anytime there is winter conditions, upgrade everything you can buy or replace, and the damn shocks, one hit and they are done. oh yea dont forget to upgrade exhaust system and springs and brakes - these damn things come so unprepared for the road.
I don't get your point. But I think the rear shocks are going out. Would probably change all 4.
Old Nov 30, 2017 | 09:14 AM
  #42
irok's Avatar
irok
as soon as you go for a ride with your new shocks you will realize how bad the old ones were.
Old Nov 30, 2017 | 05:25 PM
  #43
dr_gallup's Avatar
dr_gallup
I think my rear shocks are worn out. I hit another pothole and it went really deep. Didn't get the kind of dampening expected although it didn't bottom out- it just wasn't well controlled.
So I have had excessive rebound and uncontrolled dampening on a "one each occasion". It seems to make the rear a little squirly.
I am looking at JOC or Bilsteins (front and rear). Perhaps a JOC kit with anti roll bars? I'll see if anyone has experience with the JOC kit. No big rush but will look into replacement.
You don't seem to understand how shocks work and the advice you have already received. Most shocks have relatively low compression damping. It's the springs job to absorb the compression hit and store the impact energy. Then the shock dissipates that energy (in heat) on the rebound. So yes, when a shock wears out it is most evident in excessive rebound. This is usually noticeable by the vehicle continuing to bounce after the initial rebound. The fact that it got squirrely after one big hit probably means the wheel(s) broke traction or got airborne.
Post #2 actually did a good job of answering your question.
I would probably replace them as a matter of principal. Nearly every car I've owned had to have replacement shocks by that age. The only exception was my 350Z which was still doing fine on the OE shocks after 13 years and 130,000 miles.
Old Nov 30, 2017 | 05:38 PM
  #44
LowRyter's Avatar
LowRyter
well DrG, my question had to do with excessive rebound. You stated that excessive rebound is evidence for worn shocks. It appears you've confirmed my suspicion (even though since you replied I also had an instance of poor dampening).
Post #2 didn't address my question concerning rebound as an early sign of failure. It does a good job of explaining general conditions of worn shocks that most of us here are aware.
Now I am considering Bilstein HDs or JOC kit. I am leaning towards HDs since I don't want a harsher ride considering my roads have potholes.
Old Nov 30, 2017 | 05:54 PM
  #45
449er's Avatar
449er
CF Community Team
Originally Posted by phileaglesfan
It is like boiling water. You probably have a hire tolerance if your hand is in the water from when it was cold but if you put it in hot water right away you are crazy but you'll find out quickly that your tolerance has dropped dramatically.
That would be "higher", sorry, I had to do that
