Wheels
Old Dec 8, 2017 | 12:03 PM
07 pace car's Avatar
07 pace car
2nd Gear
Default Wheels
Will 2007 Z06 wheels work on 2007 pace car without rubbing fenders
Old Dec 8, 2017 | 12:24 PM
dahogan's Avatar
dahogan
Enjoy while you can.
Ohio Events Coordinator
2025 Corvette of the Year Winner - Unmodified
St. Jude Donor '14 thru '26
For a better response, post your question in the C6 section.
Old Dec 8, 2017 | 01:46 PM
DebRedZR1's Avatar
DebRedZR1
Moderator
CF Banner Relay Captain
West MI & JAX/NE Florida
Events Coordinator
St. Jude Donor '11-'17, '21
Moving to C6
Old Dec 8, 2017 | 04:26 PM
Dano523's Avatar
Dano523
Your pace car is a base narrow body, while the Z06 is a wide body car.
Hence the rim off set will be wrong (Z06 rims off sets put the rims farther out), and the tires will stick out past the fender. One small bump to drive the tires into the fender lips, and it will destroy the fenders. Plus, you don't have the room in the narrow body wheel wells for the wider rim/tires (back mostly).
C6
Fronts - 18 x 8.5 +56mm offset
Rears - 19 x 10 +79mm offset
C6 Z06
front: 18 inch x 9.5 inch, +40 offset
rear: 19 inch x 12 inch, +59 offset
To Wheels
