drivers window will not bump up
Old Dec 18, 2017 | 09:46 PM
george511's Avatar
george511
Default drivers window will not bump up
that is it---had battery disconnected
2005 coupe
window goes up and down fine
just will not finish that last little bit
Old Dec 18, 2017 | 10:12 PM
hdrider1's Avatar
hdrider1
Sounds like you just need to reindex the windows. Simple procedure mentioned in the owners manual after if the battery has been disconnected. I don't have the details handy, but as I recall you run the windows all the way down then all the way up, then hold the up switch in the up position for like 10 seconds, let go of the switch and then again hold it in the up position for several seconds -- may need to repeat the let go and hold up a few times. Do a search for c6 window indexing for more info.
Old Dec 18, 2017 | 10:23 PM
Vette_DD's Avatar
Vette_DD
Look in the FAQ & DIY sticky at the top of the title page. There's a thread for how to reset the window indexing. Your owner's manual will tell you this needs to be done every time you disconnect, then re-connect the car battery. Also, you'll need to do both windows. And you only need to do it once per window.
Old Dec 18, 2017 | 10:32 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
^^^^^^^ yep.....just close the door while you are inside, pull up on the window switch and hold for 3-5 secs.....all good
Old Dec 19, 2017 | 06:43 AM
Mike2013's Avatar
Mike2013
St. Jude Donor '03-'26
Old Dec 19, 2017 | 07:33 AM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
Anytime you discount your battery, you will have to re-index the windows.
I always leave the windows in the down positions when disconnecting battery.
To drivers window will not bump up
