I have a 2011 ZR1 and I have been doing some upgrades nothing that I know of that has t do with the Active Handling or traction control except I have had the console and the bezel around the Nav. unit and heater controls . So I had to disconnect the traction and active handling plugs but I checked to make sure they are still plugged in.
My traction control button turns it off and on but the traction control indicator light does not go off and the "Service Active Handling " message scrolls by.
I connected my Tech 2 and found no DTC codes in that area.
Why does it not throw a DTC code ? What could be the problem?
