Tire Pressure
Old Dec 30, 2017 | 11:03 PM
buckmeister2's Avatar
buckmeister2
Originally Posted by dpigguy
We use to have a tire engineer on forum who recommended 31 front and 30 rear pressures cold. Been using that advice for 10 years and have no abnormal wear issues. DIC is 2 psi higher. Always use same gauge to set pressures as well. Alignment seems far more problematic to tire wear than pressures.
well...that, and burnouts...
Old Jan 1, 2018 | 10:17 PM
Cherokee Nation's Avatar
Cherokee Nation
Originally Posted by Bruze
Yes! That's it!
Every Corvette owner needs at least one to carry with them at all times. When I get to the diner (5 miles away) I always check the pressure and adjust as necessary before coming back home.
Old Jan 2, 2018 | 07:42 AM
irok's Avatar
irok
Originally Posted by RobLo
You're talking about your C7 correct? Our '05's don't have a high pressure warning, do they?
your 05 does have a high pressure warning.if pressure is 42 lbs or greater the warning message will display in DIC.
