How does the front splitter attach?
Old Jan 23, 2018 | 04:37 PM
FatsWaller's Avatar
FatsWaller
Default How does the front splitter attach?
Hi All:
I'm wondering exactly how the front splitter attaches to the front bumper. I've read that there are a number of screws holding it up. What kind of screws are they, and to what do they attach?
The reason I ask is that the license plate bracket that I'm going to install slips in between the splitter and bumper, and is held by the middle 3 screws. What I'm worried about is that the screws might go into U-speed nuts, which could get pushed back as I insert the bracket, and fall out. Mind you, I don't intend to just jam it in; I'll loosen some screws to each side, and use a couple of wooden wedges to hold the gap open.
Are the screws #19 and #22 in the pic below, or are they not shown? Thanks for any assistance with this.
Old Jan 23, 2018 | 09:29 PM
Not So Fast's Avatar
Not So Fast
Its attached with regular looking sheet metal screws (black) going into some U Clips that slide over the lip of the front fascia as I remember, and they are susceptible to cracking the fascia where they contact any road.
NSF
Old Jan 23, 2018 | 11:08 PM
FatsWaller's Avatar
FatsWaller
Thanks for that. Now I'll know to be carefully so as to not dislodge the clips.
Old Jan 24, 2018 | 08:55 AM
rkj427's Avatar
rkj427
Pro Mechanic
You should be OK loosening the bolts without the clips moving, as they slide over a small portion of the fascia, and unless they get bent or deformed, they should be fine to reassemble without any issue.
Old Jan 24, 2018 | 06:54 PM
triple black c4's Avatar
triple black c4
Default license plate bracket
I have one of the brackets that you are talking about using. You just take the three center screws out and slide the bracket in and put the screws back in. I bought this bracket so I could use a bra on the car and I made it so I could put it under the splitter, but you have to be carful not to tighten the screws to much if you do this as it pulls down on the facia. I ended up going with a different kind so I can use the bra. But the one you are talking about was fine the way it was designed for. Good luck.
To How does the front splitter attach?
