Interior light stays o
Old Jan 28, 2018 | 10:09 PM
Srkegler's Avatar
Srkegler
Default Interior light stays o
Sorry guys, read the owners manual, tried searching. Just cant find out how to shut the light off that shines down from the mirror.
Old Jan 28, 2018 | 10:12 PM
Icecap's Avatar
Icecap
Try pushing in on the **** that dims the dash lights.
Old Jan 28, 2018 | 10:40 PM
LedZepper's Avatar
LedZepper
Or try pushing on the two black buttons on the bottom of the mirror. In is off and out is on. Good Luck!
Old Jan 28, 2018 | 10:48 PM
Vette_DD's Avatar
Vette_DD
Push and release. Be aware that nothing noticeable will happen until you get out of the car, close the car door, and give the car 12-15 seconds to turn off all the lights.
Old Jan 28, 2018 | 10:55 PM
Spasetrucker's Avatar
Spasetrucker
I had that problem about a year ago. I can't remember what I did, but it was simple once I figured it out.
Old Jan 29, 2018 | 05:07 AM
Srkegler's Avatar
Srkegler
Maybe the switch is broken on the mirror. Nothing happens when I push it. It shuts off after a few minutes when the car is off, on all the time while driving with the headlights on.
Old Jan 29, 2018 | 08:17 AM
lazerlemonta's Avatar
lazerlemonta
When your sitting in the seat on the left side of you close to the door, Push the dash diming button in and see if that cures it.
Old Jan 29, 2018 | 08:48 AM
ART T's Avatar
ART T
Mine started doing that after I put in LEDs.
Old Jan 29, 2018 | 11:26 AM
custompainter99's Avatar
custompainter99
same here,,only on the mirror lights though..
Old Jan 29, 2018 | 12:05 PM
ART T's Avatar
ART T
CP99 are yours dim or bright?
Old Jan 29, 2018 | 06:40 PM
dreskiluv's Avatar
dreskiluv
lazerlemonta is most likely correct
Old Jan 29, 2018 | 07:09 PM
WW7's Avatar
WW7
This is a common problem that GM has never addressed on the C6... When you get in or out of the car, sometimes your knee will hit the light switch for the mirror lights...When you have the car turned on or running, you need to push the black light switch to the left of the steering column to shut them off.. It won't allow you to shut off the mirror lights unless the car is turned on or running, this is why most people get confused when trying to turn off the lights, because the car has to be on or running for the switch to work....WW
Old Jan 29, 2018 | 07:20 PM
Srkegler's Avatar
Srkegler
Thanks, got it shut off, not sure how though.. Think it was pushing the dash light button in then pushing the button on the mirror. Was so glad to finally get it off, didn't want to try and duplicate it
Old Jan 29, 2018 | 07:29 PM
cadyshac's Avatar
cadyshac
The button on the dash controls the buttons on the mirror. I had this problem when I first got my vette. Glad you got it figured out, drove me crazy for a day or so too.
Old Jan 29, 2018 | 07:46 PM
cmonkey713's Avatar
cmonkey713
I bet this is it, happens all the time.
Old Jan 29, 2018 | 08:08 PM
EVRose's Avatar
EVRose
The next time you get in or out of your car see if either of your knees come anywhere near that button. I couldn't do it even intentionally.
Old Jan 29, 2018 | 08:11 PM
LowRyter's Avatar
LowRyter
the "push and release" is on the dimmer switch on the bottom of the dash to left of the steering wheel. It's easy to brush against it. It's annoying to be driving at night have those lights on.
I had to read the book to figure it out since I didn't know it was a twist to dim and push to turn off & on. And of course I pushed the mirror light button first and it was on too.
Old Jan 29, 2018 | 08:18 PM
SpryGeezer's Avatar
SpryGeezer
I put a Delrin lock collar over the **** in the left lower dash. Can't push it in now. Forgot what size it is.
https://www.interstateplastics.com/S...PMCSBNYC00.php
Old Jan 30, 2018 | 12:58 PM
ben z's Avatar
ben z
I never knew about the dash button! (My knee doesn't come anywhere near it though). What I've done on a few occasions is accidentally hit one or both mirror buttons accidentally while putting on or taking off the sunshade.
To Interior light stays o
