storage question
Old Jan 31, 2018 | 09:13 AM
pmetro1@gmail.com's Avatar
pmetro1@gmail.com
Navigator
Default storage question
Hi all.....should i over inflate my tires for a storage period of around two months? ( Over inflation is a very touchy subject in New England.)
Paul
Old Jan 31, 2018 | 09:27 AM
Baysider's Avatar
Baysider
Default Storage Inflation
I inflate mine to 40 psi for storage, no issues
Old Jan 31, 2018 | 09:30 AM
Turbo6TA's Avatar
Turbo6TA
2021 C6 of the Year Finalist - Modified
For just 2 months ... That's not a long time. I would not waste my time doing it.
On the other hand, I have stored my C6 for 7 months at a time when traveling overseas. Then I usually put about 40 PSI in the tires before leaving.
____________________________
Just gotta know .... Why is tire over inflation a "touchy subject" in New England?
Old Jan 31, 2018 | 12:56 PM
cadyshac's Avatar
cadyshac
a couple extra lbs per tire won't hurt just be sure to adjust when you start driving it again.
Old Jan 31, 2018 | 02:23 PM
dmk0210's Avatar
dmk0210
If you're not driving it, it really doesn't matter as long as it isn't extremely low.
Putting some extra air in there is just added insurance to make up for losing a little over time. I leave it at the same pressure as it when I'm driving it and just periodically check it.
Also flat spotting should not be an issue with a modern good quality tire.
Old Feb 1, 2018 | 12:43 PM
pmetro1@gmail.com
Navigator
Default thank you
its a Patriots thing, anytime we mention the word "inflation" the subject matter goes in a whole new swim lane.
Old Feb 1, 2018 | 03:03 PM
silverbullit99's Avatar
silverbullit99
With the good quality of tires these days, there is no need to have to over inflate. They can easily sit several months as is. As soon as the car comes out and starts rolling again they will be back to normal.
Old Feb 1, 2018 | 06:37 PM
MoeLarryCheese's Avatar
MoeLarryCheese
St. Jude Donor '17-'18
Paul
Actually, I believe under-inflation was the issue. At least that year.
Old Feb 1, 2018 | 07:18 PM
449er's Avatar
449er
CF Community Team
Are you saying that the Patriots are cheaters?
Old Feb 2, 2018 | 02:33 AM
cornel02's Avatar
cornel02
We usually set the at 40psi as well, for abour 3-5months storage.
Old Feb 2, 2018 | 03:49 AM
Don-Vette's Avatar
Don-Vette
40lbs. for winter storage here as well.
Old Feb 2, 2018 | 07:08 AM
joeking's Avatar
joeking
Cruise-In II Veteran
Cruise-In III Veteran
40 psi here as well and still on the original tire pressure sensors but in a heated garage all the time.
Old Feb 2, 2018 | 07:54 AM
Olsarge's Avatar
Olsarge
Paul
Why not just put the car on jack stands?
Old Feb 2, 2018 | 10:07 AM
itomh's Avatar
itomh
Put it on a charger and maybe a cover on it and call it a day.
To storage question
