3D Printed Part
Old Jan 31, 2018 | 10:21 PM
Canaryy's Avatar
Canaryy
Default 3D Printed Part
Has anyone designed any part for c6 using 3D printer to print?
Old Jan 31, 2018 | 10:32 PM
96GS#007's Avatar
96GS#007
Originally Posted by Canaryy
Is there any body design part for custom looking by 3D printer ?
Translation?
Old Jan 31, 2018 | 10:37 PM
Canaryy's Avatar
Canaryy
Originally Posted by 96GS#007
Translation?
😂 use ur talent my English is not good enough
Old Jan 31, 2018 | 10:45 PM
Bruze's Avatar
Bruze
Well that clears everything up.
Old Feb 1, 2018 | 07:45 AM
Ahrmike's Avatar
Ahrmike
Theres a russian vendor who made 3D printed ash tray cover replacements with switches. I think he's since swapped to using molds. I was really interested in buying a cover if it could fit my phone (iphone plus) but I guess the depth available behind the cover is limited...
Old Feb 1, 2018 | 07:49 AM
mcandrew67's Avatar
mcandrew67
2016 Corvette of Year
2015 C6 of Year Finalist
A member printed the latch to the center console
Old Feb 1, 2018 | 08:35 AM
PCMusicGuy's Avatar
PCMusicGuy
I have the center console lid latch modeled and printed. It is working successful. I need to make one adjustment to the model, which is moving the hole where the spring attaches about 1.5 mm further away from cylinder that it slips over.
Once I make that change I will print it again, retest, then make the STL file available free with either a private host or some place like thingaverse.
My next project will be the plastic seat rail covers that attach to the front of the rails and hide the bolts that hold the seat frame to the body. All four of mine have broken at least twice.
Old Feb 1, 2018 | 08:51 AM
Turbo6TA's Avatar
Turbo6TA
2021 C6 of the Year Finalist - Modified
Your English is ok
Just out of curiosity ... What country are you originally from?
Old Feb 1, 2018 | 08:55 AM
mcandrew67's Avatar
mcandrew67
Originally Posted by Turbo6TA
Your English is ok
Sounds like Miami to me
Old Feb 1, 2018 | 11:01 AM
dr_gallup's Avatar
dr_gallup
Has anyone designed any part for c6 using 3D printer ?
You don't design parts with a 3D printer, you manufacture parts with a 3D printer. For Design you use a Computer Aided Design (CAD) software package like SolidWorks. There are many of them but they are all pretty expensive. You create a model of the part in the design package then you send that model to the 3D printer and it makes the part.
There are hundreds of different 3D printers and the quality of what they build is all over the place. Most of the cheap ones are just toys, their build accuracy is low, the surface quality is low and the structural integrity is low. At the other end, GE is building single crystal jet engine turbine buckets with very high end 3D printers.
I've been using 3D printers for 30+ years and while they are "cool" I find the technology to be way over hyped. Other than a "show & tell" part to pass around in a design concept meeting or to check fit in a bigger assembly they have limited real world use for me. For my line of work a functional prototype needs extremely good tolerances, finishes and material properties. 3D printing is not particularly cheap or fast either, I can frequently get 30 real parts CNC'd faster than 3D printed.
Old Feb 1, 2018 | 11:32 AM
Bruze's Avatar
Bruze
I agree with all of that.
As a moldmaker, my experience with this goes back to the early '90s when Kodak (a local company) was monkeying with it to produce simple prototype plastic parts that were to be ultimately molded.
Back then it was called "stereo lithography" (if memory serves) and it was done in a tank filled with gel, and a computer-guided laser beam came around and solidified the portions that were to become the finished part. Something like that anyway. "3D printing" (additive manufacturing) is a new term, in comparison. My CNC mill is driven by data from my CAM software, which removes material from the workpiece. 3D printing works more or less the opposite (additive).
The Kodak parts were very brittle and would break (depending on the shape) if you dropped them on a concrete floor.
A plastics company I work with now has about a $1000 printer that they use to make prototypes and other odd things of small quantity they need -- some of which I used to machine for them.
Apparently dentists can make teeth with them now, but the finished tooth is not as durable as porcelain or gold, so the applications are limited.
But in 10-20 years, who knows where it will be. Won't matter to me!
Old Feb 1, 2018 | 11:48 AM
Canaryy's Avatar
Canaryy
I have tons of idea everything I look around new design show up in my head it’s amazing
Old Feb 1, 2018 | 11:51 AM
Canaryy's Avatar
Canaryy
Originally Posted by PCMusicGuy
I have the center console lid modeled and printed. It is working successful. I need to make one adjustment to the model, which is moving the hole where the spring attaches about 1.5 mm further away from cylinder that it slips over.
that would be wonderful job , I have a lot of idea in my head for interior and body I am working on it and I am gonna share here
Old Feb 1, 2018 | 11:55 AM
Canaryy's Avatar
Canaryy
I know sir my English is not good 3D max maya auto cad free hand ... I done all of them when I was 14
Old Feb 1, 2018 | 11:58 AM
Canaryy's Avatar
Canaryy
Your English is ok
tnx I am from Iran and I came near 1.5 year before
Old Feb 1, 2018 | 12:01 PM
Canaryy's Avatar
Canaryy
yes I saw that on YouTube but I am thinking about changing and modify parts not printing same part you know design new look for interior or exterior
Old Feb 1, 2018 | 12:05 PM
Canaryy's Avatar
Canaryy
sounds like miami to me
To 3D Printed Part
Old Feb 1, 2018 | 01:30 PM
joezr2's Avatar
joezr2
Check out shapeways. A member on here has a few designs of C5 parts available on there. I bought an ash tray replacement piece. Maybe check there and see what people have made for the C6.
Old Feb 1, 2018 | 02:40 PM
Canaryy's Avatar
Canaryy
tanx a lot
Old Feb 2, 2018 | 03:42 AM
jbc1995fb's Avatar
jbc1995fb
I tried to 3D print tires, and a transparent targa top. I also tried to 3D print headers but they kept melting. lol
