Anyone have issues with the starter button?
Old Feb 10, 2018 | 12:20 PM
webdzynes's Avatar
webdzynes
Default Anyone have issues with the starter button?
My '06 has 116000 miles but is always garaged. Lately when I go to start it, every once in awhile I push the start button and nothing. I try again and so far, it starts right up. Probaly has happened 15 times over the past 4-5 months. I had the starter replaced a few times since Ive owned the car but there is no indication that its that and all connections look good and tight. The only thing I can think of is the starter button is wearing out or perhaps the clutch sensor which indicates the clutch is pushed in in order to start. Any thoughts?
Old Feb 10, 2018 | 12:30 PM
Dave S's Avatar
Dave S
Retired & lovin' it!
You say that all the connections look good & tight, but have you actually separated the connectors to check for any oxidation on the pins? If not, I suggest you do that & use dielectric grease when reassembling the connectors.
Old Feb 10, 2018 | 12:40 PM
~STOLEN~'s Avatar
~STOLEN~
I had a similar issue with my door handles on my 07 z
The inside was corroded all to Hell. A little sand cleaned up and had no problems since.
Just be careful trying to get the button out of the dash and apart. Very easy to break
Old Feb 10, 2018 | 01:26 PM
owc6's Avatar
owc6
The clutch-position sensor will give you a CEL. If I it is that, you can try pulling up on the clutch pedal (to properly set it) BEFORE pushing it in to start.
Old Feb 10, 2018 | 07:15 PM
webdzynes's Avatar
webdzynes
Originally Posted by ~STOLEN~
+1
Thanks - any video links on how to best do this?
webdzynes's Avatar
webdzynes
What is a CEL? Do you mean a code? (nothing showing if so...)
Old Feb 10, 2018 | 07:16 PM
webdzynes's Avatar
webdzynes
I was refering to the connections on the starter. Are there others I should check as well?
Old Feb 10, 2018 | 10:25 PM
owc6's Avatar
owc6
Yes, Check Engine Light. AFAIK, every CEL comes with one or more codes that can be read.
If you didn't have one, it is highly unlikely that the clutch position sensor is the issue.
One possibility down.
Old Feb 11, 2018 | 05:10 PM
webdzynes's Avatar
webdzynes
yes - thank you!
To Anyone have issues with the starter button?
