2005 climate control stuck
Old Feb 11, 2018 | 11:25 AM
whjury's Avatar
whjury
2nd Gear
Default 2005 climate control stuck
My 2005 corvette climate control is stuck in the air conditioning mode and it will not allow me to switch functions or change temperature. The display is also not accurate as far as the degrees.
Old Feb 11, 2018 | 02:53 PM
4SUMERZ's Avatar
4SUMERZ
As a trial, have you tried disconnecting the battery to see of it's an electrical glitch. The battery disconnect just may get rid of any glitch, and reset itself.
If that doesn't work, then you likely need a new Climate Controller module.
If you decide to disconnect the battery, you will need to re-index the windows. Instructions are in the owners manual.
Old Feb 11, 2018 | 03:59 PM
69 L46 4 Speed's Avatar
69 L46 4 Speed
I had the same symptoms with my 13 GS about two years ago. It was the Climate Control Module. At least try disconnecting the battery first.
Old Feb 12, 2018 | 12:30 AM
fourth vette's Avatar
fourth vette
To 2005 climate control stuck
