Headers worth it without Mid Pipe?
Old Feb 15, 2018 | 04:33 PM
Dman302's Avatar
Dman302
In my case I have a corsa mid pipe that is 2.5 inch followed by corsa sports at 2.5 Inch....Really if the headers exit at the Stock location then obviously going with Billy boat headers would not in fact offer a restriction. Unless your 3 inch all the way the bottleneck will always be tailpipes Which typically measured 2.5 inch ID
Old Feb 15, 2018 | 05:00 PM
Adam Cifonelli's Avatar
Adam Cifonelli
So if I bought:
http://www.hinsonsupercars.com/p-860...pes-black.aspx
Would the 3 inch x pipe narrow at the end to fit my 2.5inch npp axel back mufflers?
Old Feb 15, 2018 | 05:28 PM
saplumr's Avatar
saplumr
Originally Posted by Adam Cifonelli
So if I bought:
Yes
Old Feb 15, 2018 | 05:35 PM
Adam Cifonelli
Originally Posted by saplumr
Yes
Ok cool. Thats what I'll prob go with. Hinson has some good reviews and a good 500 cheaper than Kooks or AR.
Old Feb 16, 2018 | 01:54 AM
Ahrmike's Avatar
Ahrmike
Originally Posted by I say NA to boost
I guess I don't quite understand why you would want to connect to the stock mid pipe. The whole idea of going to longtubes is to improve flow through the exhaust. The stock cats and H pipe are horribly restrictive, thats why a ton of people replace them. For nearly the same price you can get a catless mid pipe and headers that will significantly improve flow through the system; and in turn power if its tuned for it.
The "long" part of the LTs - the long runners - are what increases power. The BBs have a long runner with a shorter merge section. From all the dyno comparisons theres almost zero power difference between LT+x vs BB LTs. Price differential was 300ish for BB vs Kooks/ARH/etc. 30% off is not "a little more" for basically no power gain.
Old Feb 16, 2018 | 06:25 AM
Dcasole's Avatar
Dcasole
Really ... do you always belive what you read ...
And the power gain has nothing to do with the collector design and the scavaging and it is all about the long tube ..... ??? Right..... I have a prime peice of land to sell you in Florida
Dave
Old Feb 16, 2018 | 11:40 AM
Adam Cifonelli
Dave
From what I understand the scavaging is very important. Help the exhaust escape faster correct?
Old Feb 16, 2018 | 12:23 PM
Dcasole's Avatar
Dcasole
Yes it's all about the scavenging , the lenght of the tube and the diameter affect where in the torque band the power will come in , small diameter long tubes make power down low and large diameter tubes make power higher , now there are many debates on what's the best size for our car but thats not what we are talking about here .......
it is all about the most important part , the collector and its design as this is what facilitates the scavenging of the cylinders . Ask any drag racer how many different collectors designs they have ( their collectors slide on and off to facilitate change outs )
Get the x pipe , even if u have to save a bit. Running headers without the crossover pipe is like taking a shower with your shoes on ....
Dave
Old Feb 16, 2018 | 12:33 PM
Adam Cifonelli
Dave
Yeah once I get my tax return Im going with the Hinson Headers with catted x pipe. Only question is 1 3/4 or 1 7/8.
Old Feb 16, 2018 | 03:12 PM
Dcasole's Avatar
Dcasole
Oh boy ,now you done it , you just opened up Pandora's box ... can't wait for all the replies on this one lol lol lol
So the question you need to answer is are you going to do more work on the car like cam .. heads etc of just keep it stock with headers ?
Dave
Old Feb 16, 2018 | 03:35 PM
Adam Cifonelli
Dave
No heads work.. maybe...and a very small maybe get a cam one day. Probably not though. Bolt ons is probably as far as I go.
Old Feb 16, 2018 | 03:45 PM
Not So Fast's Avatar
Not So Fast
Simple experiment on how headers work, very simple
NSF PS if I'm not mistaken Hinsons X pipe uses the "H" type crossover instead of the "X" type, controversy there also but at least you know which is which.
Old Feb 16, 2018 | 07:37 PM
  #33
449er's Avatar
449er
CF Community Team
No big cam/heads/forced induction? Go with the 1 3/4" tube size. And if I were you, I would buy the matching X pipe along with what ever header manufacturer you choose to eliminate any headaches
Old Feb 16, 2018 | 09:07 PM
  #34
Dcasole's Avatar
Dcasole
Here we go .... let the games and all the internet legends begin lol lol lol
Dave
Old Feb 17, 2018 | 01:43 AM
  #35
Ahrmike's Avatar
Ahrmike
Dave
When I did my due diligence and research no tuner ever explicitly said the BBs made less power than any other LT+x combo. Hell, most tuners said merge spikes would make you less HP than their dyno could accurately measure.
The BBs have LTs and are 1-3/4 or 1-7/8 just like any other LT. Length of the tubes are roughly the same. Merge area is a little short so you -might- lose power. Same idea as the merge spikes.
When I stated its the "long part that makes power" I OBVIOUSLY did not mean the longer the better. I meant the length of the tube for these applications is what creates the scavenging effect that makes power.
I stand by my claim that the whole point of long tubes is a long straight section of pipe - and as long as that section of pipe has relatively smooth curves, the length is all that really matters in terms of headers. My OEM system has an X pipe too so theres no difference there.
Most of my info comes from reading up on well-known tuners recommendations - no first hand experience but probably the 2nd best method of learning.
A guy to search out would be anthony (previous LGM employee) who had a lot of good info on header sizing.
Old Feb 17, 2018 | 01:44 AM
  #36
Ahrmike's Avatar
Ahrmike
I found most tuners recommend the larger 1-7/8 for the LS3 and the 1-3/4 for most LS2s. Still, you probably wont notice a difference in power with either until you start doing stuff to it.
Old Feb 17, 2018 | 08:10 AM
  #37
Dcasole's Avatar
Dcasole
Now that you worded it this way ...... much different context !
Dave
To Headers worth it without Mid Pipe?
Old Feb 17, 2018 | 08:38 AM
  #38
Dcasole's Avatar
Dcasole
PERFECT EXPLINATION Bobby of why the collector is so important in the design of the headers
its all a science , tube length , collector design etc all to achieve a desired outcome ,
At the risk of over simplification because there are so many other factors involved , one being reversion ..., where do I want the gain to come in on the power band ?
With all things being equal do I want more power on top and a little less torque ... use large tube , do I want a little less total power but more torque on the bottom , use small tube
Old Feb 17, 2018 | 09:19 AM
  #39
88redconvert's Avatar
88redconvert
Originally Posted by itomh
Bing! you are absolutely correct. That's the same reason I'm running B&B LT's headers on my Z06. Bolt right up, no modification needed.
I did not know this but had wondered about it. Thanks for the info.
Old Feb 17, 2018 | 11:40 PM
  #40
buckmeister2's Avatar
buckmeister2
Looking at buy the Hinson headers to go with my always open NPP. Question is.. Do I need the mid pipe to go with it? Or is the stock one still fine?
Is your stock mid-pipe going to line up with the header outlets? Have you checked the measurements?
there is nothing special about the mid-pipe, but it has to fit to the headers. The mid-pipe is just tubing for the exhaust. As long as it is "X", or "H" configured, it will balance the pulses, and work fine. The exception would be when you get to maybe 500HP and more...you would want a full 3" pipe all the way. No need for that on a mostly stock LS3.
Yes, possible over-simplification, and I understand that. He is not going to Turbo/SC, and probably not a cam...
