LS3 engine ID
Old Feb 18, 2018 | 04:54 PM
tlyoung003's Avatar
tlyoung003
8th Gear
Default LS3 engine ID
I purchased an LS3 engine with a 6L80 transmission for a project I am working on. I was expecting to see the engine numbers 12584724 with 12600821 heads. What I have is 12621766 and 823 heads. Did GM make an LS3 motor using the LS9 block with the 823 heads? Just wanting to understand what I have. Thank you
Old Feb 18, 2018 | 06:22 PM
Vette_DD's Avatar
Vette_DD
The Corvette Black Book shows the same number you were expecting for the 2008 block, but the 2009 block has the number you got. The 823 head is designated as a pu (possible usage) head for 2009.
Old Feb 18, 2018 | 08:52 PM
tlyoung003's Avatar
tlyoung003
8th Gear
Does this mean I have an L92 motor and not LS3?
Old Feb 18, 2018 | 09:46 PM
Vette_DD's Avatar
Vette_DD
Only thing it says is that block & head are 376 ci and 430 HP. The LS9 is also 376 ci, but 638 HP. I'd say it's an LS3.
To LS3 engine ID
