Engine light shutdown
Old Mar 23, 2018 | 06:57 PM
tomcat377's Avatar
tomcat377
1st Gear
Default Engine light shutdown
Steady engine light on and 2005 c6 will not start with fully charged battery.No sound from starter when ignition activated.
Old Mar 23, 2018 | 07:29 PM
BlindSpot's Avatar
BlindSpot
Isn't modern technology great. The car is just waiting to tell you what's wrong with it. You're just a simple scan away from all the info you'll ever need.
Old Mar 24, 2018 | 12:27 PM
Landru's Avatar
Landru
Hopefully.
In a perfect world.
OP, check codes.
Need a reader, car's dead so parts store's out.
Have to buy/borrow/rent one, plug it in see what's there or not.
Old Mar 24, 2018 | 02:34 PM
rkj427's Avatar
rkj427
Pro Mechanic
May be better to check and ensure that there is voltage at the starter electrical connection. That would give you idea if it may be starter or ignition switch.
You could use a test light, but a voltmeter would be a more accurate tool to use.
Good luck getting it sorted out.
To Engine light shutdown
