Oem tpms
Mar 25, 2018 | 08:55 PM
Oem tpms
I have found it difficult to air my tires to the correct PSI using the onboard PSI indicators. Are these inherently inaccurate ?
Mar 25, 2018 | 09:02 PM
Mar 25, 2018 | 09:04 PM
Cruising
Mar 25, 2018 | 09:13 PM
Quote:
Originally Posted by
hitekcm
They don't sample often enough to use them to tell you when to stop when filling.
You should use a hand-held gauge to fill, and then check to see what they are actually reporting. That way you know exactly how accurate they are.
Your altitude also makes a difference; generally they don't read as close to a hand-held the higher you go.
Mar 25, 2018 | 11:53 PM
Use a quality gauge, inflate cold tires to spec, drive a bit, wait a while until tires again cold, check TPMS pressure.
I like this Pro Products analog gauge because it never needs a battery:
Mar 26, 2018 | 12:54 PM
Just use TPMS to tell you when there is a low tire. You should use a good gauge to air up the tires.
Mar 26, 2018 | 09:12 PM
Cruising
Tonylmiller
yes thats true
Mar 27, 2018 | 10:02 AM
^^^ x2
