TPMS help needed
Old Mar 26, 2018 | 01:08 PM
Kimball's Avatar
Kimball
Default TPMS/restricted mode - help needed
So my tpms all read xx and service tire monitor keeps coming on the dic.
I got a reset tool and although it goes into learning mode I couldn't recognise any sensors. I am now fairly certain there aren't any in my wheels.
To prove it I just had a sensor shipped to me and put it into learning mode and and it was immediately recognised as left front. But then had to stop as no others too learn. However it remembered it and the car is convinced I have a flat left front and 55mph limit with reduced handling.
How can I disable or turn this off until my other sensors arrive and get fitted.
Can I make it forget or will it just go back to the xx after a while of not getting any updated readings. I've taken the new sensor out of range for now, I hope
Old Mar 26, 2018 | 02:17 PM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
Taking it out of range should do it.
Old Mar 26, 2018 | 03:54 PM
Kimball's Avatar
Kimball
Thanks. Do hope do, as the daily got collected for repairs today so I might have a week of 55mph. Lol.
Old Mar 27, 2018 | 12:46 AM
HOXXOH's Avatar
HOXXOH
The 55 MPH message is simply a warning and not a requirement nor a condition that limits your speed. I have a sensor that occasionally is not read and shows the XX or Left Rear Tire Flat and then the 55 MPH warning. I've driven over 90 just to test the "restriction" and it never had a handling issue either. Just don't do anything stupid and you'll be fine.
Just push any other button to clear the message and don't let those messages bother you. I've also driven about 10K miles with no sensors and speeds well into triple digits without any issues.
Old Mar 27, 2018 | 01:28 AM
Dano523's Avatar
Dano523
What the story on the car?
Now to you?
If no TPMS are installed in the tires, then someone may have had the TMPS sensors in a pressuried car, so they could do quick tire swaps isntead. If something like this, then could have been that they removed the can when they sold the car.
Of could be that the sensor batteries are dead in the tires, or someone threw on different year rim and tires on the car, and the sensor in the tires are not the correct year for your car year, will not program into the RDCLR instead.
Hence there was a changer in the TPMS sensors in 2010 and later vts, and 2005 to 2009 year cars used the older style sensors instead.
Old Mar 27, 2018 | 02:40 AM
Kimball's Avatar
Kimball
OK, that's God news, the sensors haven't worked since I got the car but I thought it was a hard ecu limit with the message. Thanks
Now to you?
It is possible all 4 sensors are dead but I have also noticed that all the valve stems are rubber, and they don't even all look the same. The new sensor I've just had delivered, a schrader, has a very distinctive stem.
I've also got horrible tyres on the rear and no idea of their life, but nasty tramlining as well. So I've got 4 replacement bridgestones on the way with new sensors coming too.
Seems a but pointless taking off tyres I hate to put the sensors in then still having the tyre issues. Although I'm a little surprised how bad they are as I've always thought of pirelli as a good brand.
Old Mar 27, 2018 | 10:06 PM
Dano523's Avatar
Dano523
Look like for some reason, the tires on the car never had TPMS installed in them in the first place.
Since you have TPMS, and one will program into the car, not only do you have the correct year, but correct MHZ models as well.
Hence the USA model vets TPMS are 315mhz, while the export models are 416MHz instead.
As for your tire selection, here on the other side of the pound, we tend to drive the vets only in the hotter/dry weather, so will run summer performance tires on the Vets like Super sports or Super Cups isntead.
You on the other side of the pound with cooler weather, and even more rainfall that you will have to tend with, such "Scary then hell in the Rain" summer performance tires may not be the best choice for you isntead.
Old Mar 28, 2018 | 12:11 AM
HOXXOH's Avatar
HOXXOH
Actually only C5 and C6 exports are 433 Mhz, while all C7's are 433 Mhz, export or not.
Old Mar 28, 2018 | 05:29 AM
Kimball's Avatar
Kimball
Yes agreed, looks like they just changed wheels or tyres or both and didn't fit them. The wheels have big ugly 20mm spacers on too, so probably not even vette wheels.
So 4 tyres and 3 more sensors on order.
You are very correct about the weather and tyres, although at the moment the horrendous trampling is the biggest issue. Never felt anything quite like it and had plenty of large tyred jags before. So I've either got a horrible set of tyres or some suspension/steering play or maybe both.
Not 100% sure about my tyre choice until they go on, but certain they can't be worse. And going back down to factory sizes will also help I think too.
To TPMS help needed
