Front Spring Retainer Bolt
Old Apr 13, 2018 | 04:52 PM
DAMCars's Avatar
DAMCars
Default Front Spring Retainer Bolt
Can anyone confirm the part number for the retainer bolts that secure the front leaf spring? Through my research, I believe it's 3545602 but I cannot definitively confirm this. Thanks in advance.
Old Mar 25, 2021 | 12:17 AM
John S 1961's Avatar
John S 1961
Lock washers only provide a visual indication that the nut is not loose. Clamping force via torque holds things together. Split washers do not provide clamping force. Split washers do not go under bolt heads. Washers do. Flange bolts are used on the bellhousings.
