Squealing under acceleration?
Old Apr 13, 2018 | 06:53 PM
Chris86581's Avatar
Chris86581
Default Squealing under acceleration?
Whenever I'm on the road and I accelerate I hear squealing or chirping from the front of the car whenever i push on the accelerater. The harmonic balancer, serpentine belt have been replaced I took off the AC belt but I still hear the noise my wife says she hears it from the back... any thoughts???
Old Apr 13, 2018 | 08:45 PM
Jstan2014's Avatar
Jstan2014
How long ago was the HB replaced? I’ve heard of OEM replacement balancers going bad as quickly as the original. Was an aftermarket balancer installed? Many are much better than the GM OEM’s.
Old Apr 13, 2018 | 10:04 PM
Chris86581's Avatar
Chris86581
It's the slp 25% I put the car in park and stepped on the accelerater and no noise I think it might be a bearing
Old Apr 14, 2018 | 09:27 AM
Jstan2014's Avatar
Jstan2014
I’m at a loss. Someone here is bound to have some ideas..,bump to the top. Good luck.
Old Apr 14, 2018 | 12:27 PM
Old Man in a C's Avatar
Old Man in a C
Squirt some belt dressing on the belt and see what happens.
Old Apr 14, 2018 | 07:49 PM
ErikR's Avatar
ErikR
I'm no mechanic but to me squealing usually comes from something like a slipping belt. How's your tensioner?
If it's not the belt, there are a couple of idler pulleys that might have a bearing making noise under load/acceleration....
Old Apr 15, 2018 | 12:03 AM
FatsWaller's Avatar
FatsWaller
Doesn't the underdrive balancer have a smaller diameter? When you replaced the belt, would the stock belt still fit, or would you need one that was shorter to maintain proper tension? Just asking.
Old Apr 15, 2018 | 07:37 AM
Tpatt's Avatar
Tpatt
Check the idler and the tensioner. Remove the belt and spin them by hand. Most times if they are bad you will be able to feel and/or hear it. Had them where they would only make a noise under acceleration, or certain rpm range.
Old Apr 15, 2018 | 08:53 AM
ErikR's Avatar
ErikR
Originally Posted by Don-Vette
QUOTE: "I took off the A/C belt but still hear the noise" FYI your car only has one belt.
Pretty sure there's two.........
Old Apr 15, 2018 | 09:10 AM
Yokesc5's Avatar
Yokesc5
I use the wooden handle of my squweegee, great stythoscope, just go around at the closest hard points to the pulleys etc, you will know which is the screamer.
Old Apr 15, 2018 | 02:04 PM
Vet Interested's Avatar
Vet Interested
One belt...really?
Old Apr 15, 2018 | 04:47 PM
HOXXOH's Avatar
HOXXOH
The tensioner needs to be closer to the tighter (upper position) than the lower position.
Old Apr 15, 2018 | 08:56 PM
Chris86581's Avatar
Chris86581
yeah i replaced it with a smaller belt the 25% is smaller than the stock
To Squealing under acceleration?
