What I did today . . .
#241
Received 1,136 Likes
While my vette has its headlights off (sent them to get new lenses replaced) and my front end is in peices I decided to finally change out my air dam spoiler. It as really damaged and it was missing the passenger side peice. Baught a new one and installed and it looks pretty good
I also thought of buying splash guards for the car. I didnt buy gm ones... I got ebay ones for 80 bucks or so and they look oem. Only thing I'm concerned about is the 3m tape. But even if it comes out it doesnt look too bad I guess. It's still uses push pin retainers.
I took a look at the cabin air filter (since I only discovered where it was last night) and it was time for a new one. Turns out it's on the upper passenger side firewall held by 3 ring clips. Easy peasy. Although it doesnt look like those filter fit in well. Ehh
I put GM guards on my car I think three years ago. It has been through the car wash numerous times and the tape is still holding up fine.
Cabin filters: No, they don't fit very well, seem to be slightly big. Have to be careful putting them in.
Attachment 48333511
#242
I dont know. these dont feel too sticky, but maybe that's just me. I've only test fitted them for now without the 3m since i'm going to get my car all polished and paint repaired on some areas. Then its splitter and rocker panels
#244
Had a good rain Thursday, salt is gone! The ground in front of my barn was dry enough today, so I took the Vette out for the first time. When I got up to the road I was flicking through the DIC and realized the tires were still pumped up to 40, so I had to go back and let some air out of them. We had a high of around 70°.
Otherwise, it started and ran like a champ. You'd never know it sat for five months. Sure wasn't like that in "the days of yore."
Attachment 48333511
Attachment 48333511
owc6 (04-07-2019)
#245
Did the Lowe's and two bar tour today. I saw a car -- a red convertible, top down -- coming towards me that I thought for sure was a C7 -- had the same shape headlights and L-shaped LED driving lights.
This all happened in a few seconds, but as I waved I realized it didn't look quite right and probably wasn't a Corvette. I checked the butt in the rear-view, and for sure it wasn't a C7 or any other Vette. Had maybe round-ish or close to round-ish tail lights. Nothing else on the butt looked Corvette-ish.
I'm assuming it was European, but does anybody know what car looks similar to a C7?
I did see an actual C7 and tailed a Maserati. I have to get out of the woods (and drive 20 miles) to ever see cars like that.
Attachment 48341433
Attachment 48341433
#248
Well, if you're going to wave at a car, then I'd be flopping my hand, because, really, who doesn't want one?
I'd have one if it was workable.
#249
Someone asked me this evening, after working on the Vette all day, if I would ever find I car that I could just leave alone and not mod/tinker with. I said, sure but I must win the lottery first. That way I could have Ferrari build the car exactly the way I want it.
#250
Here is a Motor Trend test of a 2018 that I ran across, and had to read, whilst searching for the picture I posted.
Price as tested: $465,509. So if you had them custom-build it to your specs, I wonder where that number would end up?
#252
I got out of the woods today and headed to where all the money is (Canandaigua). I just got a quick glimpse, from probably 1/4 mile away, of a bright red mid-engine. At first I'm thinking "C8!" Eh, well no. I didn't see any Vettes or other mentionables.
I was headed for Lowe's to get a new Weber grill; I had to throw my old one away last year. I'm in the store thinking, even after seeing the box, that it should easily fit in the front seat (I had the top off, stored in the rear.)
Wouldn't fit in the front seat so I'm thinking NP in the hatch. So, get the top out and put it on, box won't fit in hatch -- it lacked several inches before it would close. So I ended up jimmying it into the front seat, resting against the shifter. But it all worked out okay.
I'm itching to cook a pork roast tomorrow and now I'm all set.
Attachment 48333445
Attachment 48333445
#253
Polished the baby up this morning and went bar-hopping. Perfect day, 80, low humidity, no clouds.
I stopped at a winery near me >>LINK<< and snapped this pik:
Pork roast is doing great!
#254
Received 3,633 Likes
2016 C6 of Year Finalist
#256
Received 1,596 Likes
Don't you have one of those pick up things ? What happened, the Toyota wouldn't start ?
#258
#259
Besides, I was pretty sure the box would fit in the car somehow. It was a lot closer than I thought, but it all worked out.
Toyota is still new with 11k miles, and starts fine.
Attachment 48333511
#260
Received 1,789 Likes
Had rotors and pads installed on all 4 corners. Sourced the brake kit from Summit Racing, which was good experience. Used PowerStop kit PWR K1445-26. Work was done by Wallace Chevrolet, another good experience. Took the vette to the local back roads to follow the brake-in procedure. Next step is to remove the wheels and clean and maybe paint the barrels. Don't know if I'll paint the rotor hats. They are plated and we'll see how long before they start to rust. On the other hand, maybe there's too much silver there now. Flat black looked ok before.
