window regulator help
Old Apr 27, 2018 | 10:52 PM
ldscamaross's Avatar
ldscamaross
Default window regulator help
Hey guys I have been trying to figure out what is going on with my driver window regulator but I am stumped. I rolled the window all the way down one day and when I tried to roll it up it doesnt move at all. I charged the battery thinking it may be low same problem. the passenger goes up and down fine. I took the door panel off and I could hear it click but wouldn't move as if something was catching. I took out the window and pulled out the regulator and looked at the wire routing for a snag. it all looked good. I took the unit apart being careful not to release the tension on the system. and tried the motor. it works fine spins both ways. all the winding inside are fine also. I switched the motor with another spare motor I had thinking it might be a weak motor and reassembled everything and tried it and same problem it still wont go up. I did notice when I reconnected the battery that it moved just slightly like when you open the door and the window goes down. this is a 2007 z06. Any ideas before I buy a new regulator.
Old Apr 27, 2018 | 11:13 PM
simplegto's Avatar
simplegto
St. Jude Donor '11-'12-'13-'14
I had mine replaced a few months ago and the cable was all twisted. an $800 adventure for parts and labor. I was told that the pulley is usually the problem.
