Bowed Facia?
Old Apr 30, 2018 | 03:31 PM
AV8TOR536's Avatar
AV8TOR536
Default Bowed Facia?
I was under the front end of my 2005 C6 the other day and notice the cut outs(1 screw in each )
where those steel bumper things that scrape on low clearance are, dont know exactly what they are called but the the fiberglass is bowed,its like that on both sides,I don't remember them being like that before,I haven't hit anything,is that suppose to be like that?
Old Apr 30, 2018 | 04:03 PM
wayback's Avatar
wayback
Yes.
And those metal things are the lower radiator supports so be careful and don't hit them hard.
Lots of problems if you do.
Old Apr 30, 2018 | 08:04 PM
AV8TOR536's Avatar
AV8TOR536
Originally Posted by wayback
Yes.
Thanks!
Old May 1, 2018 | 12:21 AM
Cherokee Nation's Avatar
Cherokee Nation
Originally Posted by AV8TOR536
Thanks!
I think you are talking about the "Air Dams" one on each corner made of hard plastic stuff.
Old May 1, 2018 | 03:02 AM
joliett's Avatar
joliett
I had the same problems. Further investigation proved that the lower radiator support were broken, which caused the bow in the bumper fiberglass. I'm replacing the lower radiator support as soon as I get brave.
Old May 1, 2018 | 09:26 AM
AV8TOR536's Avatar
AV8TOR536
I don't think thats it,I pushed up on them and they are solid,I have heard though to replace them is a pita.
Old May 1, 2018 | 10:21 AM
GREENKAR's Avatar
GREENKAR
You can buy what they call FANGS from Saccitycorvette.com. They work well and will definitely help protect the radiator supports from being scraped or possibly broken. Very
Old May 1, 2018 | 10:29 AM
cgladish's Avatar
cgladish
Default lower radiator support
those metal brackets are the part of lower radiator support.
this portion functions as a "skid plate" for the front end.
to many hits on this, will cause the bracket to final break.
this causes the fascia to sag a bit. and if it has broken,
you should also notice more scraping of the air dam then usual.
( if no more scraping, then you should be ok ).
I paid $300 for parts, + $100 for my tire shop to install.
I would get a flashlight and do a search from the top side.
it could be broken and wedged in place.
good luck!
Old May 1, 2018 | 11:16 AM
AV8TOR536's Avatar
AV8TOR536
I just went out and opened the hood and looked down at the supports and no cracks or breaks..look new..knowing GM and the way they put cars together,it might just be like that as the other post said..I guess I just never noticed it.
Old May 1, 2018 | 11:34 AM
cgladish's Avatar
cgladish
Default Fascia
hopefully all is good.
it may also be bowed to allow it to flex, in case of minimal contact.
if it was rigid, It would probably snap when hitting something
( i.e. curb ).
if you drive it long enough, you will be replacing it.
unless you drive only on the Bonneville salt flats.
Old May 1, 2018 | 02:31 PM
SacCityCorvette's Avatar
SacCityCorvette
Supporting Vendor
From: SacCityCorvette.com in Sacramento Ca Join us on Facebook!
St. Jude Donor '12,'13,'15,'16,'17
Hi AV8TOR536
You should install a pair of our Fangs before there is anymore damage and eventually possible breakage of the radiator support. The Fangs eliminate the friction that the soft aluminum skid plates/radiator support cause when they scrape and dig into what they are scraping on, which can cause the support to break. The Fangs just slide like a bearing surface.
Here is a link. Click the Fangs picture, there you will find two versions of Fangs and videos.
http://www.saccitycorvette.com/C6Products.html
Thank you,
Christian
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
Old May 1, 2018 | 02:40 PM
AV8TOR536's Avatar
AV8TOR536
Yes.
Yes..you were right,I removed the one bolt holding the bowed part of the fascia and it is molded that way,it didn't spring back straight and it is not under any pressure but I took the bracket off that holds it and it was bent a little,I bent it back but it has that form to it so....im not worried about it.
Heres a pic of the bracket.
cgladish's Avatar
cgladish
Default fangs
Originally Posted by SacCityCorvette
Hi cgladish,
You should install a pair of our Fangs before there is anymore damage and eventually possible breakage of the radiator support. The Fangs eliminate the friction that the soft aluminum skid plates cause when they scrape and dig into what they are scraping on, which can cause the support to break. The Fangs just slide like a bearing surface.
Thank you,
Christian
do these attached to current "skid" bars? if so, I can see where it would help in reduces damage to the bars. but since these bars are part of the radiator support, they would still transfer any impact encountered. I believe that my damage may have been a combination of the previous owner's & my history. I've only had the car since 01/2017, and only noticed the damage about 6 months ago. I do not remember any major impacts, but a few minor ones
( beyond parking lot berms ).
if your fangs attached were mounted independent of the rad. support, I could see that being a plus.
since I've replaced the rad. support, I don't recall having any contact in the area. if do end up needing to replace it in the future, I may go your route.
please let me know the details on this anyways.
thanks!
Old May 1, 2018 | 02:48 PM
AV8TOR536's Avatar
AV8TOR536
Hi AV8TOR536
Thank you,
Christian
Those look like a nice item but I have never scraped those supports since I have owned the car, 5 years,looks like the previous owner scuffed them on something,I know they hang there and Im very careful but if I decide to buy fangs,I sure will order some from you.
Old May 1, 2018 | 02:55 PM
cgladish's Avatar
cgladish
Default fangs
I only remember bottoming out once, hard enough to hit rad. supports.
I'm guessing that was the hit that did it in.
beyond that, my biggest issue is not clipping the front bumper on parking berms.
Old May 1, 2018 | 03:00 PM
AV8TOR536's Avatar
AV8TOR536
My car doesn't come within 50 ft of those yelliw parking berms..lol...I park way out in the lot!😅
Old May 1, 2018 | 03:09 PM
cgladish's Avatar
cgladish
I'm not the worrying type of person, but I've heard & seen enough when people try to distance themselves. their will also be "that" person
who will F*&^ with you. I've been lucking enough I guess in just trying to blend in. although I will try to park as protectively as possible.
at 6'2" 300lbs, I always hate when someone parks a bit too close, and I end up looking like a circus animal trying to get in.
To Bowed Facia?
Old May 1, 2018 | 09:45 PM
SacCityCorvette
Supporting Vendor
thanks!
Hi,
Yes, they attach to the skid bars that are part of the lower radiator radiator support. They minimize the impact by sliding instead of gouging in and getting traction that can break the support.
Christian
Old May 1, 2018 | 09:48 PM
SacCityCorvette
Supporting Vendor
I can see from your pictures that somebody has already scraped the skid bars.
Christian
Old May 3, 2018 | 09:33 AM
gliot1's Avatar
gliot1
St. Jude Donor '12-'13
I had the same problem and after staring at it for sometime I decided to take a deeper look. I see you have scrapes on the radiator support, so I suspect the same issue. I am guessing that the radiator support/protective frame is bent. Remove the lower trim and inspect it close; hard to see distortion sometimes. It is a fairly easy fix, taking about 2 hours and about $275. Don't short cut and cut and splice wires like many suggest here, all wires that feed through end up at the lights, so simply disconnect. Make sure to buy a frame with the threaded inserts already installed. You will need a second set of hands as this is decent size and can be awkward to maneuver on your own!
Bear in mind, many think the frame is a "skid plate" or the like, but it is actually designed to protect the radiator.....
