A6 launch advice
After some advice,
I've had a few high powered automatics before, but not had launch problems, (nothing official, just some back road fun and testing) but I'm struggling to get my 2006 A6 off the line, so rather than wear my tyres out I'm hoping you guys can give me some short cuts.
So in the pouring rain and very wet roads I'm pretty happy, regular 4-5 seconds 0-60s and 1/4 mile in about 13 dead with 112 final speed. Didn't think that was too bad in the wet, however in the dry I'm up nearer 6 or even 7 seconds on the 0-60. Tried in comp mode, too much wheel spin, and full traction, just bogs down a bit even holding the brake and revving to about 1200.
So for best launch presumably I need a little wheel spin and maybe better throttle control. No launch on this model I don't think.
Obviously I can practice until I get it right but interested in opinions to save wear and tear.
I do get a lot of practice in the rain over here of course, in the 73 days since I got the car it has rained on 54 of them according to the local weather reports, and I'll be surprised if it's that few!
and driven a lot of powerful cars LOADS more twitchy and unstable than this awesome thing. That's what is annoying, 5 second times in the wet without really pushing at all, then trying quite a bit harder 6+ seconds.
But, I digress...
All the nannies off (comp mode). I powerbrake to about 1300, release and walk it just 3 or 4 feet, then nail it. I get a little wheel spin, but a pretty good hook. I have not been to a track to get actual results. If I brake until 1700, then nail it, I spin all the way into second, plus a bit. I do not consider myself above average on launches, so you might get better or worse results, and many on here are certainly better than I. And, so much depends on tires. If you are running the OEM Goodyears, they are too old to give you a good launch.
But, I digress...
Anyway that is great advice, I think the 3-4 feet is where I'm going wrong, I'm trying to feather the wheel spin and once it goes in the dry I find it either than catches and boys down or just starts sliding sideways.
Tyres are 1 month old bridgestone non run flats. The good years I had on it were scary and dangerous. Thought my suspension was broken at first!
That's great advice thanks and a good starting point.
and driven a lot of powerful cars LOADS more twitchy and unstable than this awesome thing. That's what is annoying, 5 second times in the wet without really pushing at all, then trying quite a bit harder 6+ seconds.Anyway, my lecturing aside, If you have all the nannies on, it will detect wheel spin and pull timing (TQM - torque managment). If you want a good 0-60 or 1/4, you will have to get grippy tires and at least put it in comp mode to allow for some spin before the TQM gets engaged. I think all the guys getting really good 1/4 times are running drag radials at the very least with a high stall torque. Im sure a good drag shock setup helps corvettes a LOT since corvettes are sprung pretty hard and don't transfer much weight to the back stock. A lot more knowledgeable guys will probably give you some tips on how to launch/what to mod for the best times.
for a quick list of mods to get you quickest, fastest check out:
https://www.corvetteforum.com/forums...challenge.html
But take all those times with a grain of salt - the quickest guys are probably in very optimal conditions - cold weather, low altitude, sticky track...
already been over it and checked. Anyway, I guess in the rain the nannies are getting optimum times with the reduced grip, just need to practice more in comp mode from the sound of it.
Not going to be doing many mods I don't think, it was more about a best technique. Which you've given good pointers on.
Doubt I'll ever even take it on a drag strip
just a little frustrated at getting worse times in the dry than wet. And if optimum conditions are cold and low altitude that will be good, lol, 1st May and it's 3 degrees C and pretty much the whole county is at about 400'. We need some good weather, it's been a horrible year so far.
Thanks.
Thanks.
Hey...theres a thunderstorm on the course....a little Golf anyone ??.....
