Shift knob backwards?
Old May 1, 2018 | 10:30 PM
slow_zo6's Avatar
slow_zo6
Default Shift **** backwards?
I ordered a round ball shaped shiftknob(twisted shifter) for my '06 Z and it's easy enough to install but with the included screw put in the 6 speed script is upside down. Did I miss something or is this an error on the part?
Old May 2, 2018 | 12:35 AM
Dano523's Avatar
Dano523
Bolt channel on the shifter shaft is through drilled and through taped, so the bolt to retain the shifter ball can be threaded in either from the left, or the right on the shifter shaft.
So with your shifter ball, bolt channel to the right, and the bolt installed into the shifter shaft threaded channel from the right as well.
Old May 2, 2018 | 01:02 AM
slow_zo6's Avatar
slow_zo6
In other words the bolt should be able to go in from the right side? I didnt get that good of a look but Ill have to check it out.
To Shift knob backwards?
