temperature display blinking
Old May 2, 2018 | 11:38 AM
whjury's Avatar
whjury
2nd Gear
Default temperature display blinking
2005 temperature display blinking
Old May 2, 2018 | 12:50 PM
stingray71's Avatar
stingray71
If you are asking for help, you should provide as many details as possible and ask a question.
Old May 2, 2018 | 12:57 PM
Dano523's Avatar
Dano523
Hows your soldering skills?
Hence you have cold solder joint of the controller boards that is causing the flashing problem, so your options are to pull the controller apart to fix the boards solder joints, or to replace the controller isntead.
To temperature display blinking
