Handling
My C5 "seemed" to be more stable, didn't have to make as many steering corrections.
Of course it may just be my imagination, 150K in the C5, only about 5K in the C6.
Dealer put new Firestone RF on which I'm stuck with for a while.
I could justify changing the suspension, to cheap to throw away good tires.
Anything else I could try, check.
To see if someone lowered the car, park it on level ground and using a measuring tape from the lip of the fenders to the ground, you should have
Fronts fenders lips to ground around 26 1/2"
Rears fenders lips to ground around 28 1/8"
If you end up with the fenders lips to ground lower than this, then go find a shop that can corner balance the car, as well as change out the after market ride height adjusters back to oems. Hence bank that the after market ride height adjusters failed in the first year they where installed.
Have the alignment checked, hence all four wheels.
If you are not going to track the car or push it hard, then have the alignment set for Pfad pure street specs, which will keep the front inside of the tires from wearing out faster than the outside of the tires from the OEM aligment specs.
Print and take the the sheet with you to hand to the tech,
http://www.pfadtracing.com/docs/camb...t-settings.pdf
Also, have the tires road force balanced to weed them out as well. Hence it not uncommon to have a tire that will not road balance correctly that has to be replace with another new tire, plus a bent rim will show up bright as daylight during road force balancing that may need to straightened as well.
Millage would help, but if under say 40K, the suspension should still be tight and not a problem. If above 60K, then base shocks could be giving up the ghosts instead.
Lastly, pull the GM service history, and even a carfax report on the car, to make sure that the car was not in a wreck, and possible a bent frame that was not caught on the wreck repairs or even steering rank replacement that was replaced with a rebuilt rank (that still may have problems), instead of a new one.
Read this thread from a couple of days ago. It may provide the answer you are looking for.
Thanks again,
Thanks again,
The wandering and poor tracking were dominant on ours and a reputable tire store that replaced the tires and did an alignment gave us a silly excuse for the problem saying that what they described as "ridge walking" was a characteristic of that car. I call BS since when properly aligned by a GM tech at a dealership it was fixed, stable and tracked perfectly END OF STORY!
I have an `08 1LT and it tended to "float" while cornering. Bumpy roads, under power, made it feel like all four wheels were going in all different directions. Didn't feel planted at all.A new set of DRM Bilstein shocks made a huge improvement. The OEM base shocks are quite weak from the get go. Comfortable ride though.
This would absolutely be the next item on my checklist. An out-of-alignment condition -- ESPECIALLY at the rear -- can make a C6 handle very badly. A few months ago an incompetent alignment tech at a local Firestone shop messed up my Red something awful. I had to immediately take it to my dealership to get it corrected. Very smooth sailing after that.
Oh, also I had to raise my car to the low end of the factory specs (before the alignment). This seemed to reduce bump steer.
