Shocks
Old May 7, 2018 | 12:57 PM
dannyboytop's Avatar
dannyboytop
Cruising
Default Shocks
What are the best shocks for magnetic ride on 2007 c6 conv.
Old May 7, 2018 | 01:02 PM
Vette_DD's Avatar
Vette_DD
Magnetic Ride has special shocks you have to buy, and they are expensive.
Old May 7, 2018 | 03:41 PM
buckmeister2's Avatar
buckmeister2
DD is correct, but I would like to know why you are asking? How many miles on your car, and why do you think you need to replace them?
Old May 7, 2018 | 05:27 PM
drew_c6's Avatar
drew_c6
I can't find the F55 magnetic shocks on Cultrag or other OEM suppliers, but here's a very recent thread posted where the OP was quoted $4k to have them replaced at the dealership. Another member in the thread said it cost hem $2k to replace them himself:
https://www.corvetteforum.com/forums...ew-shocks.html
Like DD and Buck said, unless you 10,000% HAVE to have them, you're probably better off changing them for a non-magnetic option.
Old May 7, 2018 | 06:30 PM
C6ToGo's Avatar
C6ToGo
All 4 Delco shocks are $1438 + shipping. Rockauto with 5% discount promo code.
Old May 7, 2018 | 06:45 PM
buckmeister2
those are not F55 shocks, which is what the OP apparently has, are they?
Old May 7, 2018 | 08:05 PM
dannyboytop
Cruising
Default Shocks
thanks for the help I probably go another route one front shock is leaking.
I am just learning how to navigate this web sight
Old May 7, 2018 | 08:20 PM
buckmeister2
Okay, you need to be a bit more patient here. We are trying to help, but you aren't giving us much info. I asked you how many miles, and got no reply.
The shock is leaking? Who told you that? I know...the dealer, right? Or, a repair shop? Or, if you saw it yourself, just wipe it off and see if it comes back soon. It is common to have a small amount of oil form on the outside of F55 shocks. Dealers and other repair shops make a killing replacing these for customers who don't understand much about shocks. Then, they sell the "good, but replaced" shocks on ebay for $1200 a set.
If you work with the many helpful people on this forum, you will learn a lot, and probably save a lot of money in the long run.
Old May 7, 2018 | 08:28 PM
dannyboytop
Cruising
Default Shocks
car has 97000 miles I saw oil on outside will wipe down and watch to see what it does.i will let you know in a few days.Again thanks for the help
Old May 7, 2018 | 08:42 PM
Dano523's Avatar
Dano523
Just a FYI, but the shock fluid in the F55 shocks has iron partials in the fluid.
If the shock is leaking, and you wipe the fluid off with a paper towel, then the wet part of the paper towel that has any shock fluid on it, will be able to be picked up with a refrigerator magnet.
Hence this is the quick way to test fluid that someone tells you the shock was leaking as shows you the oil at the shock area, since if they shot some oil on the shock area to try to fool you, it's not going to have the iron partials in it instead.
Old May 7, 2018 | 09:17 PM
dannyboytop
Cruising
Default Shocks
Thanks I will do that for sure.
Old May 7, 2018 | 11:23 PM
buckmeister2
Good luck! Seems to me I recall reading that GM said the shocks are good for 150K...who knows? Let us know in a couple weeks what you find.
Old May 7, 2018 | 11:36 PM
Vette_DD's Avatar
Vette_DD
I think we've had a few who had the F55 shocks that didn't last that long, but it was only a very few.
Old May 8, 2018 | 01:50 AM
703's Avatar
703
The shop I take my car to has been saying my F55 shocks are leaking for 2 years now and should be replaced...The car rides fine so I haven't replaced them. They quoted me 4k for all new shocks.
If I do replace mine i'm ditching the F55 ones and picking up a set of bilstein sports. They seem to get good reviews here on the forum and honestly I can't tell the difference between sport and comfort mode.
Old May 8, 2018 | 10:49 PM
C6ToGo's Avatar
C6ToGo
yes...are the MSRC shocks. fronts about $350 ea.....rears about $370 ea.
Don't believe the hype that they are $700-1000 apiece.
Old May 8, 2018 | 11:07 PM
buckmeister2
though still pricey, that is not too bad. if you go to a dealer, expect to pay about $3500 for parts and labor. $1500 is much better, for sure.
To Shocks
