P2135 Throttle Positioning Sensor
Looks like the diagnostic steps to fix P2135 all lead to either fixing a wire, replacing ECM or replacing the TB. Good luck.
bt
https://www.walmart.com/ip/ACDelco-2...Throt/47338491
Others: Amazon...Rockauto....search "217-1617" or"12570790"
Don't think you really need a scan tool to do throttle re-learn. Here is shop manual procedure:
Throttle Learn
Important: Do NOT perform this procedure if DTCs are set. Refer to Diagnostic Trouble Code (DTC) List - Vehicle .
1] Start and idle the engine in PARK for 3 minutes.
2] With a scan tool, monitor desired and actual RPM.
3] The ECM will start to learn the new idle cells and Desired RPM should start to decrease.
4] Ignition OFF for 60 seconds.
5] Start and idle the engine in PARK for 3 minutes.
6] After the 3 minute run time the engine should be idling normal.
Important: During the drive cycle the check engine light may come on with idle speed DTCs. If idle speed codes are set, clear codes so the ECM can continue to learn.
⇒ If the engine idle speed has not been learned the vehicle will need to be driven at speeds above 70 km/h (44 mph) with several decelerations and extended idles.
7] After the drive cycle, the engine should be idling normally.
⇒ If the engine idle speed has not been learned, turn OFF the ignition for 60 seconds and repeat step 6.
8] Once the engine speed has returned to normal, clear DTCs.
Control motor side of the TB is retained to the TB via security hex bolt, so with them removed, you can pull the motor plate side apart to clean the swipers and stat contact surface to solve the problem.
As for cleaner, CRC electrical spray contact cleaner (red can, not the blue one).
The throttle vain side of the TB as a slot end on it, so pretty hard to screw up the index when you put the motor plate back on.
When you put the bolts back in, use Blue 242 loctite.
