service active handling 3 codes
Old May 8, 2018 | 08:57 PM
2012CyberGrayGS's Avatar
2012CyberGrayGS
Default service active handling 3 codes
C0710 Steering position signal malfunction
C0035 Right rear wheel speed sensor circuit open or shorted
C0040 Right front wheel Wheel speed sensor circuit
I will start out that this just happened after the shop replaced my oil pan gasket and dyno tuned. Not quit sure if it happened before the tune or not. Wasn't quit clear. He said code was pending. When I go home I was able to pull up the codes.
1. Is there something, 1 thing that could be causing these 3 codes to come on? Motor came out to do gasket could they have gotten a wire to cause it all?
2. Could the steering sensor cause the other 2 codes?
3. Could it be air in the brake system if they had to disconnect brake lines?
4. Anything else?
Old May 8, 2018 | 09:14 PM
2012CyberGrayGS
Is there 1 connection that they could have missed that would cause these to come up? Where would that wire/connector be?
Old May 9, 2018 | 06:39 AM
Katie22's Avatar
Katie22
So I had a similar issue happen with my car. It turned out to be the ABS controller failed. Apparently this is a pretty common thing to go bad with our cars from what I have read. Needless to say the component is up there on the drivers side by the steering rack. It could have easily been bumped when they replaced the oil pan gasket.... Just an idea.
Old May 9, 2018 | 10:01 AM
2012CyberGrayGS
Thanks. Any information is helpful. You never know for sure what i can be but it is good to know all the places to check.
Old May 9, 2018 | 10:06 AM
Landru's Avatar
Landru
Assuming you know battery's good, load-test good?
Worked before 'tune' & motor work, doesn't now.
Taken it back to shop?
I'd start w/ them, money is they've something to do w/ this. YMMV
G/L, BTTT
Old May 9, 2018 | 05:21 PM
2012CyberGrayGS
Just got it fixed. I took a chance taking it to a local dealer with the tune while still having a warranty. They just needed to re calibrated the steering angle sensor. They did it for me for free. Feels good to have it done.
Thank you all for you input.
To service active handling 3 codes
