i tried the window indexing procedure. Short version, long one, single, both together....not working.
This happened after what seems to be an electrical malfunction...Tried to start the car..made a bizarre noise but didn't crink at all...Nothing was working. Left it to rest for like an hour...when i came back, started like normal, only problem left, the driver window wont come up.
Disconnect battery, wait 5 - 10 minutes, reconnect & try again. If there was a cliché, this will hopefully reset everything and you'll be able to index the windows. If it doesn't work, may need to take in to be checked out. Good luck
ok guys....i was trying different things before i saw these messages. Thanx for the replies.
I took off the fuse under passenger floor...waited a couple of minutes, and it worked. Thank you all. Now i have to figure out what happened in the first place
Speaking of the passenger side fuse block, I accessed mine last week to repair an issue with the interior lights and there wasn’t a cover over it. Everything I’ve seen or read talks about a cover that you unscrew to remove and that makes sense but mine just had the fuses open to the backside of the carpet I am the third owner so maybe it got lost in the shuffle somewhere along the way?
My is covered with a piece of 1/8" of plexiglass only to keep dirt and maybe water from that area and I also have the Loyds rubber floor mats.My only passenger is my 80 pound four legger..........
