Good pick up on power for headers with 25hp about the norm, but your still giving up a touch after the 5.6K point. Hence with your tune, the motor is going flat at 5.6K instead.
Hence by pushing timing a touch more and leaning out AFR after 5.6K, you can gain a touch more HP and get the motor bounce hard off the rev limiter instead.
05 MZ6, all stock LS2 motor/stock exhaust, on stock OEM air filter system to boot.
Note, base HP with OEM tune for a M6 on a LS2 will be 350RWHP/350RWT, with 411hp/411t at the crank. Attachment 48339858
Thanks Dano
My dyno tune was on a Mustang which I am told often shows lower numbers than a Dynojet with smoothing. My butt dyno thinks it's 400-410 HP.
