2009 Power Convert Top Issues
Old May 11, 2018 | 06:18 PM
habib's Avatar
habib
Default 2009 Power Convert Top Issues
I am looking at a 2009 Convert. that has a power top. I read some pros and cons on the issues with this top. I really like the car and won't be using the top that much but don't want to get stuck if there is a problem.
Any suggestions is Greatly appreciated. Thanks habib
Old May 11, 2018 | 06:23 PM
919cw313's Avatar
919cw313
2018 C6 of Year Finalist
Does the top work correctly? If yes, then you're fine.
Old May 11, 2018 | 09:54 PM
habib's Avatar
habib
I did not buy the car yet. I am going to the dealer in a few days and want to be sure there are no issues with the power top before buying it
Old May 12, 2018 | 04:53 AM
Knob Jockey's Avatar
Knob Jockey
St. Jude Donor '11-'12-'13-'14-'15
Take a look at an Owner's Manual and you can learn how to operate the top manually, if there is ever an issue with the power mechanism.
In general the C6 has more than it's share of quirks, but this Forum is a great resource for solutions.
And, because the car has been around for so long, every thing that can go wrong has already happened to someone else.
Good luck with your 'research'.
Old May 12, 2018 | 10:01 PM
enventr's Avatar
enventr
Sometimes the straps stretch and the top will hit the tonneau cover. Make sure that the top by the rear window does not touch the tonneau cover. If it does the dealer should fix it.
Old May 13, 2018 | 03:22 PM
yellow2007's Avatar
yellow2007
I agree with Enventr. See if the tonneau cover hits the window either when going up or down and if it does, have the dealer replace the two straps.
Old May 14, 2018 | 07:19 AM
habib's Avatar
habib
Thank you all
To 2009 Power Convert Top Issues
