Rear Clip
Old May 11, 2018 | 07:30 PM
DDT01's Avatar
DDT01
Cruising
Default Rear Clip
How do you remove the rear clip on a 08? I cannot find any information under "How To" I just want to remove the plastic so I can install the stock vacuum lines for an NPP exhaust.
Old May 12, 2018 | 12:47 AM
HOXXOH's Avatar
HOXXOH
Seriously though, your car will not run any better, look better, or be worth more with stock OEM vacuum lines than just a rubber hose run under the carpet or in the rocker panel.
Old May 12, 2018 | 02:46 PM
HK770's Avatar
HK770
https://www.wholesalegmpartsonline.c...category=19425
Old May 23, 2018 | 08:38 PM
DDT01's Avatar
DDT01
Cruising
I found that I did not have to remove the rear plastic Just the taillights and I could reach through to the NPP exhaust.
To Rear Clip
