Door won’t open/window won’t close
Old May 26, 2018 | 10:37 AM
rjemison1109's Avatar
rjemison1109
Default Door won’t open/window won’t close
Forst things first yes I searched this topic a lot, I cleaned my putter door handle pad and replace the inner button with a new gm one.
Randomly the interior/exterior power buttons for the drivers door only won’t allow me to open the door. When it does it from the outside and I close the door the window will keep that little space to allow it to close for a while until whatever’s wrong gets the hint that the door is actually closed. I’ve been all in the door checking connections etc. any idea?!
Old May 26, 2018 | 10:44 AM
EVRose's Avatar
EVRose
If the passenger side works ok swap the outside door pad to the driver side and see if there is any change.
Old May 26, 2018 | 10:52 AM
rjemison1109
it does it from the inside too, have to use the manual handle. The red light on the door flashes too it seems when it’s not working properly (not sure the indication of that)
To Door won’t open/window won’t close
