my car is a 2011 auto gs with 47xxx miles. Drove it to work today ( 45 minutes one way ) with no problems, car sat for 10 hrs and on the way home the security light came on on the gauge cluster. The following symptoms happen:
- the radio would blink on and off
- the window switches lights on both doors would blink on and off
- the npp valves sounded like they would open slightly and then shut
- on my hud the oil life bar would read 63% ( normal ) and then reset to 100% and then back to 63
- no check engine light
- it blinked service vehicle soon once for a second and then went off
- my fuel gauge, oil gauge and temp gauge went to 0 ( but read fine on the dlc )
- check fuel system flashed once
im at a loss for what to do. The car drove fine through all this but this ain’t the first time it’s done all this. I’ve had to replace 2 plug wires and went through 4 batteries in 4 yrs. any help would be greatly appreciated, thanks
With gremlins like this the battery is usually the first suspect but you've dealt with that part so I suspect there is a wiring issue somewhere. You don't say if there are any mods on the car but that could be an issue.
Read through this thread with similar but not exactly same issues. I can't think of anything to suggest that isn't in this discussion. Spoiler alert, the bottom line is presented in the first three lines of post 1:
Also my car only does all this at random. I could drive it for a month and nothing happen and then one day it will do this all of a sudden. I have also noticed that this happens when ever I hit the lock button on the fob twice. When I exit my car I hit the button twice for the horn to sound so I know it’s locked.
